Speedometer cable trouble
  • Thread starter Thread starter 1968wardog
  • Start date Start date May 19, 2011
1968wardog
Hollywood, california
May 19, 2011
  • May 19, 2011
I have a 1990 gt with manual 5 speed tranny without cruise control. My speedometer cable is no good and I need to know How many teeth my speedometer GEAR has and if its left or right hand driven. I threw out the old cable with the gear thinking autozone would have the complete speedo with gear. The old gear was white and my rear gear ratio is 3:73. Im driving around without knowing how fast im going so i need your input please
f8tlfiveo
My wife likes my spool and blow-off valve.
Aug 8, 2007
1,585
102
64
Lancaster, PA
May 20, 2011
  • May 20, 2011
Did you throw the vehicle speed sensor away too? I am pretty sure the cable will not come with a new one..
1968wardog
May 24, 2011
  • May 24, 2011
no the sensor is still attached. I was told i have 3.73 gears in the rear. i had a white gear in there before.
97gsr
31
  • May 24, 2011
i think that the white gear is a right hand drive and it has 21 teeth which is for a 3.73 rear end
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
May 24, 2011
  • May 24, 2011
If the sensor is still there, then the speedo gear is still there top. The speedo gear attaches to the end of the speed sensor which is inserted into the transmission.
The speedo cable slips into the end of the speed sensor and has a square cable inside. If your vss is still there, all you need is a speedo cable for a car with speed sensor and just slip it in.
But to answer your question...it's a white 23-tooth driven gear, 8-tooth drive gear inside
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Drivetrain Speedo gear ate itself
  • keel
  • Aug 15, 2024
Fox 5.0 Mustang Tech Aug 15, 2024
AeroCoupe
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
New to this
  • 5.ohCS
  • Nov 1, 2026
2005 - 2014 S-197 Mustang -General/Talk- Nov 1, 2026
5.ohCS
