Speedometer replacement???????????
  • Thread starter Thread starter fourmustangs
  • Start date Start date May 5, 2005
F
fourmustangs
92
Houston
May 5, 2005
  • May 5, 2005
I have a 87 5.0 notch with aod.
I just got a 140mph cluster to replace the 85mph.
Is this a direct replacement or do I need to replace a speedo gear or something?
what do I need or nothing at all?
trbkrb
1,976
Houston, TX
May 5, 2005
  • May 5, 2005
This has been covered dozens of times, but basically it depends on what cluster you have. If it is from a 89 Mustang, or it is the FMS replacement speedo, (with a flat bottom on the cluster) then you will not have to do anything at all, just swap it over. If it is from a 90-93 car (with an arch cut out on the bottom, above the steering shaft) it is not a direct fit, the wiring is all different. If that's the case, you have two choices. Either rewire the plugs to match the newer cluster, or swap out the speedo part and install it in the older cluster. But that again is not a direct swap since Ford changed the gauge face clear plastic backings and how they mount in the clusters!
Either way, you will not have to do anything with the speedo gear unless you alter the gears in the rearend of the car. All the speedos are calibrated the same, for the same number of cable turns per MPH, so it should read the same as the one you are replacing.
Where in Houston are you? We have a lot of local guys on www.westsidemustangs.com It is a great place for local help and info and such.
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Electrical Lincoln Mark VIII Replacement Fan Motor
  • AeroCoupe
  • Sep 26, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
AeroCoupe
C
Drivetrain TV cable replacement--aftermarket or search other models?
  • chazmanaz
  • Dec 21, 2025
Fox 5.0 Mustang Tech Dec 22, 2025
AeroCoupe
