Hey all,
(using both r&p and rack and pinion for easy search) I know this has been discussed before in threads, but I'm not sure if Degins' granada-based swap helps the rack and pinion issue, or if there are other disc brake conversions that have a spindle that has a shorter tie rod hold or a shorter spindle in general. The idea being that with the reduced r&p travel, if you "choke up" on the spindle, it will move farther when the rack moves. Just wondering if this feature is in any spindle, regardless of the other details of the swap. I may soon embark on a coupe-based daily driver and want to get the best possible steering radius if I go r&p. Or may just go borgeson to try out those kits.
So what's the current state of the aftermarket spindle market vis-a-vis rack and pinion steering?
Thanks,
70vert
Thanks,
70vert
It sounds like a good plan, though, and you could :Track: - it would sell to the Pro Touring set as well.
