spool for daily driver?
I'd pass for a driver by all means. Avoid it. If you will type in spool on the search feature you should find plenty about them. A spool basically allows no variation in the wheel speed...they both turn equally at all times which can make the vehicle abit squirrely in the rain, turning hard, etc. A locker might be an option for you but its somethin you need to get used to and maybe practice with in a wet parking lot. My recommendation is for a limited slip so it will allow much greater safety in bad conditions but still give you posi.
