spring perch question
  • Thread starter Thread starter medicman681
  • Start date Start date Jul 18, 2006
M
medicman681
  • Jul 18, 2006
can anyone tell me which way the spring perches go in there is a stop tab on one end but i dont know if it goes toward the inside or outside. thanks, wendell.
Cupid
162
  • Jul 18, 2006
The spring tab goes towards the inside(close to the engine). Both sides.
T
tylerrocks
514
Big Spring, TX
Jul 19, 2006
  • Jul 19, 2006
and the bottem tip of the coil spring sits up against it.
G
grego37
576
Fresno CA
Jul 23, 2006
  • Jul 23, 2006
I just noticed mine are on the other way, the tab (stop) is towards the outside (fender Side)
should I switch them around?
and why?
thanks
Cupid
162
  • Jul 23, 2006
Good question.
Oooooh. Good question. I don't know that one, but I do recall mine being set up with one side in and one side out. Apparently that affects the ride height a little. Don't know if that's true or not.
bnickel or one of these other smart guys should be able to help you out on this one so stay tuned.
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Jul 24, 2006
  • Jul 24, 2006
Do you have stock upper arms? I ask because Global West says to reverse them when using their arms. Other aftermarket arms may be that way too.
bnickel
5,640
lubbock, texas
Jul 24, 2006
  • Jul 24, 2006
the perches are supposed to be on the inside so the spring doesn't come unseated at full droop. the spring is loaded more on the inside when the suspension droops that on the outside and the tab will keep the spring from popping loose from the perch. all said it's not a huge deal if they are on backwards but i would at least make sure the perches are positioned the same on both sides otherwise you could see a minor difference in ride height from one side to the other and the suspension could be loaded differently from side to side.
G
grego37
576
Fresno CA
Jul 24, 2006
  • Jul 24, 2006
thanks guys.
I do have global west upper arms.
however when I do jack up the car my springs basically are loose at full sag. So I think I will reverse them for that reason.
I will call global west first to make sure its ok.
M
mustangdave
2,976
North Carolina
Jul 24, 2006
  • Jul 24, 2006
Your car will never see that much suspension drop unless you are jumping it like Gone in 60 seconds.
bnickel
5,640
lubbock, texas
Jul 24, 2006
#10
  • Jul 24, 2006
  • #10
grego37 said:
thanks guys.
if you have dropped the UCA's like GW recommends and have a non-stock spring it's not a big deal. my springs almost fall out when i jack the car up and i haven't even done the shelby drop on i yet. i can change the springs on my car without a spring compressor and i almost don't even really need a prybar either. once i get opentracker roller perches installed i doubt i'll even need the prybar for what little bit i do now since the binding from the stock rubber perch bushings is pretty much the only thing keeping the springs in well and the shocks of course. it really isn't a big deal since most aftermarket high rate springs are that way especially if the UCA has been dropped
G
grego37
576
Fresno CA
Jul 24, 2006
#11
  • Jul 24, 2006
  • #11
ditto.
when my car is jacked up, I can grab the spring and pull it out (if the shock wasnt there it would fall out by itself)
Its becoming a hassle , whenever I go to let the jack down, I have to slowly release it , and guide the tops of the springs back where they belong.
Ive done the shelby drop, and have shortened my global west springs. I was contemplating limit straps to fix this problem, but if turning around the perches might help, its worth a try.
G
grego37
576
Fresno CA
Jul 25, 2006
#12
  • Jul 25, 2006
  • #12
I asked Global West, they reccomended them be flipped around (tab stop outside toward fender) when using their Upper control arms.
They said it works better with their negative roll kit. some geometry thing.
I'll just have to live with the springs falling out whenever I jack the car up for now, future plans to install limit straps.
67coupe351w
424
Portland, OR
Jul 26, 2006
#13
  • Jul 26, 2006
  • #13
Before my MII install I had the shelby drop and 1/2 coil cut off 620 springs. I had to zip tie the tops of the spings so they would not come bouncing out of my fenders when I jacked the car up. I had planned to install limiting straps as an extra per-caution (just incase I had to jump an accident to get away from the cops). But as was already said, its fine for driving, just be sure the springs seat back correctly after you do jack the car up.
It's all water under the bridge now with the shock towers missing
jerry S
1,365
52.22N 5.12E
Jul 26, 2006
#14
  • Jul 26, 2006
  • #14
I got the same information from GW.
O
Opentracker
20+ Year Stangneter
Feb 4, 2004
516
#15
  • Jul 26, 2006
  • #15
It's a clearance issue with thier upper arms. If the spring perch is put in like the original ( tab twards the inside), it hits the back of the arm. It's not a geometry deal since it bolts in the same place.
John
doug68hoss
413
australia..along ways from my stangs
Jul 27, 2006
#16
  • Jul 27, 2006
  • #16
i wish my springs would of dropped out..instead of shooting out like a rocket..
M
Bent Rear Spring Perches
  • Miozu
  • Aug 18, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 8, 2025
PSKSAM2
P
J
Foxbody mustang throttle body return spring
  • Jakub2537
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 18, 2026
86HO5.0
J
Rear alignment issues
  • Jayjay001
  • May 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk May 27, 2026
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
M
Idle control valve
  • miser143
  • Oct 31, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 1, 2026
General karthief
