  • SN95 4.6L Mustang Tech
SPRING SWAP
  • Thread starter Thread starter Mattstang04
  • Start date Start date Dec 9, 2006
Mattstang04
1,152
144
104
St. Louis, MO
Dec 9, 2006
  • Dec 9, 2006
Im getting the bullit suspension kit for my 04 GT. I was just wondering everyones opinion on the best way to remove and install the new front springs. This job is going to be fairly shadetree. More than likely jack and 2x4 style. I have very limited access to a lift, very limited. Whats the best way for a do it yourselfer. Also any good advice on cc plate installs would be appreciated.
helty
some Ukrainian's enjoying a handjob via my credit
Mar 30, 2005
1,461
Baltimore, MD
Dec 9, 2006
  • Dec 9, 2006
The rear springs are easy.
The fronts are too if you have a jack that can raise the front end high enough to allow the A-arms to fall as much as possible. You can always get a spring compressor tool to help you out if needed.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Dec 9, 2006
  • Dec 9, 2006
Make sure you have something to tie the springs with until all of the tension is out. Don't want them flying out at you.
Just raise the car as much as possible to allow for clearance of the springs. Also I'd suggest shocks and struts while you are doing the springs.
forum155pl
520
the 509
Dec 9, 2006
  • Dec 9, 2006
When i did my first set of springs all i did on the front was put a motorcycle tiedown around the spring and around the k member to hold it in there, then i heated up the spring till it drooped down enough for the load to be off of it, then pulled it out... i had a set of spring compressors already so i just put em on the new spring, popped it in there and unbolted the spring compressors, didnt have to take off one bolt after the wheel was off... i got most my tools stolen if your wondering why i did it like that..
02FastblackGT
64
Tucson, AZ
Dec 9, 2006
  • Dec 9, 2006
It's fairly easy..deffinetly something that can be done in the driveway!! You just need most basic tools for the spring swap. I didn't "tie" my springs down with anything...just lowered the jack VERY slowly after everything was disconnected. Then, I proceeded to jack the car up as high as SAFELY possible & you basically have to push down on the A-arm to slide the old spring out & to slide the new sping in (it helps to get some assistance with this). Once the new spring is CORRECTLY sitting in the A-arm, just jack it back up & re-attach everything. I also suggest new shocks while you have everything appart...it will help you in the long run!
forum155pl
520
the 509
Dec 9, 2006
  • Dec 9, 2006
if you do anything, make sure you tie your springs in before you take em out!... you can get really ****ed up if you dont... i wouldnt take the chance..
Mattstang04
1,152
144
104
St. Louis, MO
Dec 10, 2006
  • Dec 10, 2006
Appreciate the info everyone. And I am changing the shocks and struts as well. I ordered the whole bullit kit as well as a strut tower brace and c/c plates. Should make the car pretty sweet. Thank again.
Strut Tower Help!
  • 93Nifty
  • Jan 10, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
General karthief
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
