Sputtering at high speeds.
  • Thread starter Thread starter guevara42
  • Start date Start date Dec 11, 2011
guevara42
68
Jacksonville, Fl
Dec 11, 2011
  • Dec 11, 2011
Hey folks, I have a 66 coupe, 289. Car sputters at speeds starting at 65-70 and gets worse if I try to go faster. I have changed everything I can think of. Fuel filters, fuel pump, I put in an electronic ignition about a year ago. New gas tank tank and sending unit. Anything else you guys can recommend I try? I did notice that I need new exhaust manifold gaskets because i can hear a leak and visually confirmed it. TIA.
M
MitchGT
204
Dec 11, 2011
  • Dec 11, 2011
Clean out the filter in the carb. some have them. exhaust leak would not cause this.
guevara42
68
Jacksonville, Fl
Dec 11, 2011
  • Dec 11, 2011
Fuel filter has been replaced recently. Thanks,
HookandLadder
261
St Louis
Dec 11, 2011
  • Dec 11, 2011
Check your coil. Could be cutting out at higher speed.
rbohm
6,698
550
204
tucson,az
Dec 12, 2011
  • Dec 12, 2011
start with the basics, and dont take anything for granted, even the new parts you put on as it is possible that even they are defective.
1: check your fuel pressure at speed
2: check your initial timing as well as your advance curve
3: check your fuel flow
4: check your air filter
5: check your plug wires and plugs
6: check your coil
7: check for vacuum leaks
gikort
82
Dec 12, 2011
  • Dec 12, 2011
What about the float level in your carb?
guevara42
68
Jacksonville, Fl
Dec 12, 2011
  • Dec 12, 2011
I will check the fuel pressure and the flow. This only started happening about a week ago. I did put in a new coil about 6 months ago and I think I will try new plugs and wires next. That's the only thing I have not done. Thanks.
WTFO
53
Clarks-Vegas
Dec 13, 2011
  • Dec 13, 2011
What carb and distributor are you running?
guevara42
68
Jacksonville, Fl
Dec 13, 2011
  • Dec 13, 2011
Carb and distributor are original. Motorcraft 2bbl carb and the original distributor with electronic point system. Carb was rebuilt less than a year ago and it's been a few years since dist. has been rebuilt. Opened up carb and it's as clean as can be. Thought I may find gunk but it was good. Thanks.
WTFO
53
Clarks-Vegas
Dec 14, 2011
#10
  • Dec 14, 2011
  • #10
It's vacuum advance then? Bad vacuum pot on the distro maybe? Does the car idle okay? Could be a vacuum leak on the carb somewhere. Bad accelerator pump? Easy way to find a vacuum leak is to start your car and let it warm up completely then using an un-lit propane torch, slowly pass the torch nozzle by anything on or near the intake. If the idle goes up at a particular spot, you've found your leak. It's a pain with a mechanical fan blowing under the hood. Good luck!!
horseballz
824
Las Vegas, NV
Dec 15, 2011
#11
  • Dec 15, 2011
  • #11
I use a 6-12 inch piece of hose on the nozzle of the propane torch. It allows easier access to the tight spots. I'm guessing your sputtering is due a timing curve issue. Try disconnecting and plugging the vacuum advance and go for a drive. If the sputter goes away or changes, you'll know if you're on the right track. Does the problem happen at the same/similar engine RPM/load regardless of what gear you are in?
My $.02,
Gene
PoppyMod
617
Severna Park, MD
Dec 16, 2011
#12
  • Dec 16, 2011
  • #12
Hi,
Check the wires to the "+" and "-" or "Dist" or "Bat" are correct. A polarity issue will cause your sputtering, as well.
As noted, you can be experiencing a lean condition as others have mentioned. Check all of your plugs too.
Good Luck!
Hack
1,945
Minneapolis
Dec 16, 2011
#13
  • Dec 16, 2011
  • #13
I noticed that you didn't mention plugs/wires/cap/rotor condition. I have had vehicles with a miss-fire on the highway that was caused by worn ignition parts.
A
azduffee
#14
  • Dec 18, 2011
  • #14
I once had a little piece of gasket in the fuel bowl that would get sucked into one of the jets at freeway speeds causing the same thing you are experiencing.
guevara42
68
Jacksonville, Fl
Dec 22, 2011
#15
  • Dec 22, 2011
  • #15
I finally gave in and took the car to a pro. I did everything stated by everyone. I changed everything, coil, wires, plugs, vacuum advance, filters. I opened up carb and looked extremely clean. The timing was dead on. Im waiting for a response from the mech. I'll let you guys know what it was. Thanks fellas. P.S.
PoppyMod
617
Severna Park, MD
Dec 22, 2011
#16
  • Dec 22, 2011
  • #16
Hi,
I would advise, you to request the mechanic, to return any replaced parts and provide a detailed explanation. It can only benefit you in the future.
Good Luck ......Merry Christmas!
guevara42
68
Jacksonville, Fl
Jan 2, 2012
#17
  • Jan 2, 2012
  • #17
After all that, it was a bad distributor. I swapped with a new one and car runs great. Thanks for all your help.
PoppyMod
617
Severna Park, MD
Jan 2, 2012
#18
  • Jan 2, 2012
  • #18
Glad to hear it's fixed.
....and to think in could have been a $3 capacitor?
Happy Motoring!
L
1997 V6 Starting issue
  • leanzik04
  • Mar 20, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 20, 2026
G
Sputtering/misfiring below 2500rpm
  • Godless
  • Sep 14, 2025
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2025
gkomo
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
