Sputtering thruout entire rpms
Guero
2,148
So my car is sputtering thruout the entire rpm range. But ill get like burst of power were I feel it kinda pull.... what should I start looking for? Tune up was done recently..
check for a header leak. my car does the same thing, and each time I find a loose header bolt. I've finally replaced them all with locking bolts and the problem is gone. hope this helps.
by the way it could be a million things, ignition, fuel....
Do a basic tune...cap,rotor,wires,plugs...and even change the coil...I had some weird problems last week did the routine stuff finally found it was a weak coil....hope this helps....Also when was the last time the fuel filter was change it might be time for that too....
