  • SN95 4.6L Mustang Tech
sqeaking under hood
  • Thread starter Thread starter synergy
  • Start date Start date Apr 1, 2006
synergy
  • Apr 1, 2006
I noticed a sqeaking sound under the hood i replaced the belt and tensioner pulley yet it still has the noise it only does it when the clutch is held in when the car is stopped any ideas im new to mustangs ,the sound is loud similar to a belt slipping ,i have a 2004 gt no upgrades yet with 16000 miles on it
the98stang
2,408
Clovis, CA
Apr 1, 2006
  • Apr 1, 2006
Sounds like the throw out bearing or some other related clutch problem...
T
Torinalth
952
Clayton NC
Apr 1, 2006
  • Apr 1, 2006
if it is only when you put the clutch in, then i agree TOB. now i have a noise when the clutch pedal is in its normal state, but mine goes away when i put light pressure on the pedal.... been having this issue for a while myself and havnt narrowd it down yet. but yeah, TOB is the culprit... now some people have been able to get temporary relief of this issue by taking off the cover plate from the tranny (the sheet metal box thing) and using compressed white lithium grease to hose down the central shaft (to get worked into the bearing in theory) hose it down, work the clutch, hose it again, and recover it. may or may not work, have read mixed reviews on its effectivenes. but for 4bucks and 20 min, its not bad to try. OH, do this with the ar cold..... the grease will bubble before it gets worked in if not.
Torinalth
USMstang
114
Mississippi Gulf Coast
Apr 20, 2006
  • Apr 20, 2006
Torinalth
Dude!!! You have the same noise I have. What the hell is it??? It sounds like a speedometer cable rubbing on something. If you put just a slight amount of pressure on the clutch, it goes away. IT IS DRIVING ME CRAZY. Anyone with any ideas on what this is?
the98stang
2,408
Clovis, CA
Apr 21, 2006
  • Apr 21, 2006
throw out bearing
DTNODYA
831
  • Apr 21, 2006
throw out bearing
bakos24
I find there is nothing better than a tasty wiener
87
134
NE, OH
Apr 21, 2006
  • Apr 21, 2006
Same problem here after I had my clutch installed. 99.9% say its the TOB.
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Tuesday at 5:36 PM
AeroCoupe
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
