  • SN95 4.6L Mustang Tech
squeaking belt
  • Thread starter Thread starter try2catchmy99
  • Start date Start date Mar 15, 2004
T
try2catchmy99
229
Fort Worth, Texas
Mar 15, 2004
  • Mar 15, 2004
in the mornings the belt squeaks until it warms up. Do you have any ideas, could it just be loose?
thanks
Dwight
N
ngjcs3
71
philly suburbs / state college, PA
Mar 15, 2004
  • Mar 15, 2004
thanks
Dwight
can you describe the squeaking a little better? I think I have the same sound on cold mornings. It's kinda hard to describe the sound but mine sounds like a really really high pitch horn. It comes and goes randomly. I was thinking the same thing as you that it's coming from one of the belts. But i thought that when it's cold the belt tightens
T
try2catchmy99
229
Fort Worth, Texas
Mar 15, 2004
  • Mar 15, 2004
its not a constant squeak, every other second. I just replaced the ac clutch late last year so its not that.
I am going to ask a ac mechanic friend of mine and see what he says.
N
ngjcs3
71
Mar 15, 2004
  • Mar 15, 2004
keep me posted. thanks
UofMfooTbaLL24
62
Michigan
Mar 15, 2004
  • Mar 15, 2004
I have had the same problem too... If you guys rev it up slowly and let it fall slowly, can u hear the squeal for a brief split second at around 1,000 RPM? I noticed when my car idles at 1 grand is when it makes that noise... keep me posted, thanks.
9
97BlackSteed
98
Arizona
Mar 15, 2004
  • Mar 15, 2004
New belt fixed this exact problem on my car. I think the spring tensioner was at its limits trying to compensate for belt stretching. Mine never does it now.
D
Daves4.6GT
163
  • Mar 16, 2004
I got a Gator Back belt made by Goodyear, and it stop it completely my buddys cobra was squeaking too and i told him to get a Gator Back and it fixed the squeak.....AutoZone sells them...
Dave
MPSnyper
104
Houston, Tx.
Mar 16, 2004
  • Mar 16, 2004
i used to keep a bar of soap in my truck.. dang chirp was annoying
My stang did this not to long after i got my underdrive pulleys.. New belt did the trick
T
try2catchmy99
229
Fort Worth, Texas
Mar 17, 2004
  • Mar 17, 2004
ill try changing the belt
its got about 50000 miles on it so its most liikley time to change it anyway
thanks
AJ99MustangGT
218
Fenway Park
Mar 17, 2004
#10
  • Mar 17, 2004
  • #10
Change the Belt...if you need a quicker fix get a can of belt dressing, and spray it on at start up.
T
1990 Convertible door squeaking
  • Tom77
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 24, 2026
Tom77
T
F
89 GT smog delete belt?
  • fratzke
  • Feb 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 25, 2026
fratzke
F
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
Grounding issue?
  • 86SilverFox
  • May 16, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 31, 2026
86SilverFox
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
