Squeaky brakes...
I have the same problem. Mine squeek only sometimes. Took it to the dealer KNOWING they weren't going to fix it, and they didn't. They told me to bring it back at about 20-30K and they'll see if the pads are "glazed" I promptly told him I'm not an idiot, and the brakes are only covered for 12 months/12,000 miles. I then walked out. I'm just going to replace them with some ceramics soon.
i had the same problem, take off the pads and sand them lightly on a flat surface clean out the gas groove in the pads,clean off all brake hardware and clips with brake cleaner then apply antisieze or litium grease to all pad clips and backing of the pads when they meet the caliper piston and finger side of caliper. this solved my issues, mine would squeak in the rear left only at times when braking or when slightly turning one way or the other i believe it was the metal pad backing moving back and forth on the hardware clips that are also metal and were fairly dry of lube. no repl. needed
