9 94_5.0 Founding Member Feb 4, 2002 337 0 17 Jacksonville, NC Sep 26, 2004 #1 Sep 26, 2004 #1 every time the car hits a small bump or a speed bump the front end squeeks. It did not sound as loud a few months ago but now it is really loud what could it be?
H Hotrodsun Member Jun 1, 2004 58 0 7 Salem, OR Sep 26, 2004 #2 Sep 26, 2004 #2 inner/outer tie-rod ends, control arm bushing, or sway bar bushings. I had a squeak it was one of the outer tie-rod ends
9 94_5.0 Founding Member Feb 4, 2002 337 0 17 Jacksonville, NC Sep 27, 2004 #3 Sep 27, 2004 #3 i just replaced the tie rod ends...so we can rule out that.
H Hotrodsun Member Jun 1, 2004 58 0 7 Salem, OR Sep 27, 2004 #4 Sep 27, 2004 #4 did you try lubing the sway bar bushings?
94gsl5.0 New Member Sep 7, 2004 223 0 0 seatown Sep 27, 2004 #5 Sep 27, 2004 #5 i had dirt/grime inbetween the spring and spring perch... wd40 and the next day a hose down and it doesn't squeek anymore.
9 94_5.0 Founding Member Feb 4, 2002 337 0 17 Jacksonville, NC Sep 28, 2004 #6 Sep 28, 2004 #6 i will check both of thoes and see what i come up with thanks for all of the input
Venom351R Founding Member Apr 27, 2002 4,548 41 98 MAINE Sep 28, 2004 #7 Sep 28, 2004 #7 Mine did that a few yrs ago and it was the passanger side tie rod, now the driver side one is doing it.
