  • SN95 4.6L Mustang Tech
Stalling Issues
  • Thread starter Thread starter rabidscoobie
  • Start date Start date Jul 22, 2012
rabidscoobie
616
12
48
College Station,TX
Jul 22, 2012
  • Jul 22, 2012
Ok short bit of info.
Couple weeks ago I replaced my clutch and in the process I broke the EGR sensor and had to replace with no issues.About a week later my check engine light came on,so I started looking under the hood and found that the elbow for the PCV was cracked causing a vacuum leak.
Well i replaced that now the car will idle good but it will stall alot of times when I push in the clutch due to the RPM's dropping low.
Now the check engine light is still on and the problem still there.Read the codes and they are,
P0171 (O2)
Po174 (O2)
P2195
P2197
The 2197 I was told was a MAF sensor.But Im told it also could been a vacuum leak.Im thinking that busted PCV elbow is the cause of that code.Not sure about the 2195.
Any suggestions? I made sure the O2's were connected when I did the clutch,but will give another check.
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
U.S.A, U.S.A., U.S.A.!
Jul 22, 2012
  • Jul 22, 2012
Yea the first two lead to a lean condition in both banks and the second seem to lead to a lean condition as well. Do you have a Cold Air Intake and have you had the couplings off recently, if the MAF is reading one thing and other is going into the engine, that could be your possible culprit and or a vacuum leak.
You might be running rich for a while, thats what happens when you get Lean condition to compensate for the lean condition. And vice-versa, this is what I am lead to beleive.
rabidscoobie
616
12
48
College Station,TX
Jul 22, 2012
  • Jul 22, 2012
Thx for the info.
I leading towards a vacuum leak since the elbow for PCV was gone then earlier I changed out another vacuum line that was really rotted but its still happening.
I havnt removed any couplings.The only thing I did in the engine compartment was change out what I think is a DPFE sensor right at the back top motor just above the top 2 tranny bolts.I broke the nipple for the vacuum line and replaced that sensor then it started all this couple days later.
Wonder if maybe I got a bad sensor.
This is what I replaced:
http://www.ebay.com/itm/New-Motorcraft-EGR-Pressure-Feedback-Sensor-E150-Van-Mercury-Tracer-99-98-Car-/140537558464?_trksid=p3284.m263&_trkparms=algo=SI&its=I&itu=UCI%2BUA%2BFICS&otn=21&pmod=150758567720&ps=54
Edit: No aftermarket intakes or anything,just the stock shaker scoop.
  • Gulftown980x
  • Jul 29, 2026
squeak93
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
