  • 1994 - 1995 Specific Tech
Stalling problem
  • Thread starter Thread starter JP95GT
  • Start date Start date Dec 14, 2006
J
JP95GT
17
  • Dec 14, 2006
I have been dealing with this problem for sometime now with no luck so if someone could help me figure this out that would be awesome. When my car is cold and I start it up it runs fine but if I drive it on the highway for awhile and then stop and get some gas, when I go to turn it on it starts and stalls and backfires. You can really smell the gas when this happens so it seems to be running rich. The only way I have found to correct the problem is to really stomp on the gas in first gear and sometimes it will correct itself. I have replaced the plugs, wires, cap, rotor, ignition module, MAF, fuel pump, and the distributor with no luck. Last winter it got so bad that no matter when I started it, hot or cold, it would just start and stall and I couldn't get it to correct itself. I ended up replacing the MSD ignition coil I had on it and it seemed to fix the problem. It ran fine for a couple of months and I thought I had it fixed until the problem came back and has been progressively getting worse. The only engine mods I have are a cold air intake, underdrive pullies, and bumbed timing. It seems like something is making my iginition coil go bad but I can't figure it out. Has anyone dealt with a problem like this or should I just bite the bullit and take it somewhere, which I hate to do. Please help.
MLC Stang
210
Atlanta, GA
Dec 15, 2006
  • Dec 15, 2006
JP95GT,
Sounds more like a fuel problem to me. I'd check out your fuel pressure regulator. Next time it stalls/won't start after its warmed up, pull the short piece of vacuum hose off of the top of it (that connects to the intake manifold) and see if the hose is wet with gas inside. If it is, the diaphragm inside your FPR is ruptured and your fuel pressure is going to be all wrong.
That's my 2 cents. I'm sure others will have more ideas for you.
Good luck.
20new5.0
125
Camarillo, CA
Dec 15, 2006
  • Dec 15, 2006
after it stalls and backfires, does it start right back up or does it start hard?
Therian
The Highlander
Waterloo, Ontario
Dec 15, 2006
  • Dec 15, 2006
annnd have you checked codes?
J
JP95GT
17
  • Dec 15, 2006
To answer your questions, I have not checked the fuel pressure regulator so I will have to test that this weekend. When it starts and stalls, if I try to start it again it keeps doing the same thing. When I'm driving and trying to correct it, it will backfire really loud. It almost sounds like a shotgun being fired. I pulled the codes and I forget the exact number of the code but it said it was running rich so that is when I replaced the MAF and the O2 sensors and the codes went away. It did not pull any codes last time I checked it.
Therian
The Highlander
Waterloo, Ontario
Dec 15, 2006
  • Dec 15, 2006
I assume you resetted the computer?
This seems like deja-vu (there's another thread kicking around that's very similar)
J
JP95GT
17
  • Dec 15, 2006
Yes I did reset the codes. I was buying some parts at the ford dealership and one of the technitions told me that the code I was getting was probably b/c of the MAF so thats why I replaced it. After that I reset the codes and havn't got another one since. I think I saw a thread from someone with the same problem about a month or two ago but I never saw if they ended up figureing out what was wrong with it.
A
Autobodychick07
Peoria Illinois
Dec 22, 2006
  • Dec 22, 2006
I had a simillar issue shortly after I bought my pony. I ended up replacing the stator assembly. Have you tried that?
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
All power lost at crank
  • saf_blu302
  • Mar 7, 2026
1994 - 1995 Specific Tech Mar 12, 2026
General karthief
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
