standalone wideband
I've been using an LM-1 for over a year and I am very happy with it. To make it worthwhile I'd get the RPM converter so you can log RPMs and AFR. YOu can record with the LM-1 and download to your PC or use a laptop for recording.
I have the LM 1 and rpm converter too. Its awesome but when I load my datalog to my computer the rpm is all over the place and not what it should be. Does yours do this?
It did at one time but I messed with it a little. Not sure what fixed it but make sure your RPM selection for the converter is correct. If this does not work, try going through the manual RPM calibration (see the instructions but this is where you hold the engine at 2K for 10 sec or so while the red LED flashed, then steadies). If these do not work you may want to call Innovate. They have good tech support and pick up the phone quick.
wow they have so many different kits, i dont even know where to start...
by the way does anyone know where to get a megasquirt for our cars and maybe an online tutorial as to setting one up? i couldnt find any info on them. what advantages do the megasquirt have over the PMS or tweecer R/T? thanks again
Everyone says if you don't get one that datalogs it usless why would that be. You would still be able to read or have you friend read the meter as your driving. I can see why it wouldn't be as convienent but for someone on a budget I can't see it being that bad?
Things happend so fast, you would not get an accurate read by someone looking at it while you are winding the engine up so fast. Peaks and dips happen so quick, you'd never see them w/ out datalogging.
I use the Innovative unit. It helped me a lot when I strapped a turbo to the engine. I was able to dial in the correct fuel pressure to get the car to idle and stop running so rich. It was running so rich it would make you sick. Nice tool to have and means less wasted time on a dyno.
Ahhh which one should i get... i dont know the difference between all these...
PLX
LM-1
WMS??
then the Tweecer and PMS
Megasquirt????!!
Which is the best for self tuning?? I am willing to buy a complicated unit as long as their is a forum devoted to it, I can learn how to use it. But where can I buy a megasquirt?
