Starter getting stuck?
  • Thread starter Thread starter 87GT 306
  • Start date Start date Aug 11, 2005
87GT 306
260
Springfield MA
Aug 11, 2005
  • Aug 11, 2005
I have a mini starter on my mustang. After the engine fires, the starter stays engaged for about 4 seconds. Is this normal?
bsedwebt70-5.0
320
Charlottesville, VA
Aug 11, 2005
  • Aug 11, 2005
The 92-93 mini starter has to be wired different than the 1991 and older model big starter to make it work right - there are 2 wires going to the mini starter - the little one and the big one -- up at the solenoid you take the big red wire off and put it on the battery side of the terminal and put the skinny wire on the switched side of the soilinoid and that will fix that problem for good - I do not know if the 1992 and 1993 solenoid is different than the 1991 and older ones or not - check that to make sure. You need to know that the mini starter has a built in switch that makes it work that way - I know it sounds strange but it is true. Been there - done that.
HISSIN50
34
129
Aug 11, 2005
  • Aug 11, 2005
I would also note that using two solenoids can cause the starter to stay engaged longer than it should. I would have run the skinny wire right to the new starter's piggyback solenoid.
OL' WHITEY
273
Weddington, NC
Aug 12, 2005
  • Aug 12, 2005
My stock mini starter did the same thing at 130,000 miles. It worked fine, but after it started and the gear retracted back in the housing, it was still spinning and because the bearings were worn, it made a squeely sound. Very embarrasing! I just bought a new one. No problems.
stang22
1,318
Washington, D.C.
Aug 12, 2005
  • Aug 12, 2005
Don't rule out a bad ground as well. If it can't find a good ground, that could be a problem as well.
Tim
Electrical Starter solenoid green wire?
  • 387lx
  • Jun 1, 2026
Fox 5.0 Mustang Tech Jun 2, 2026
AeroCoupe
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
Electrical Mini-Starter Wiring
  • RekeHavoc
  • Jul 25, 2025
2K
Fox 5.0 Mustang Tech Aug 24, 2025
Mustang5L5
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
M
2004 v8 convertible
  • Mikeycrownvicluver
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
Mikeycrownvicluver
M
