Starter keeps running
  • Thread starter Thread starter PJB
  • Start date Start date Oct 13, 2007
1 of 2 Next Last
P
PJB
131
Rotterdam, NY
Oct 13, 2007
  • Oct 13, 2007
Lately my car's starter keeps running even after the car is started.
To stop it from running I need to rev the motor up high and then its fine.
It seems to happen more often in cool and/or damp weather.
I replaced the starter solenoid on the fender tonight and nothing changed.
Whats the problem?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 13, 2007
  • Oct 13, 2007
When it happens, pull the small red/blue wire off the starter solenoid. If it stops, the ignition switch is faulty. If it does not, either the starter solenoid has stuck the contacts toether or the starer is dragging. and not releasing.
ttop88
42
indiana
Oct 13, 2007
  • Oct 13, 2007
Is it a mini starter? If so make sure that the starter wire and battery wire are on the same post. If it is wired like the big starter it will do as you describe.
P
PJB
131
Rotterdam, NY
Oct 13, 2007
  • Oct 13, 2007
Its the stock starter.
I pulled the red and blue wire off and it still does the same thing.
The starter keeps cranking even after I pull the key out of the ignition.
I just had a neighbor that works on cars look at it and he seems to think its the ignition switch sticking on.
He had me turn the key to the on position (not start) and jump the terminals of the solenoid to start it.
Even when doing that the starter stays on.
ttop88
42
indiana
Oct 13, 2007
  • Oct 13, 2007
I would second the swith.
P
PJB
131
Rotterdam, NY
Oct 13, 2007
  • Oct 13, 2007
I just took it out and Im going to get a new one in a few. Hopefully Ill be able to fix this issue today.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 13, 2007
  • Oct 13, 2007
The red/blue wire is the power from the ignition switch that turns the starter solenoid on. When you remove it, the starter solenoid has no power for the electromagnet that closes the stater solenoid contacts. If it keeps running after you remove the red/blue wire, the ignition switch is not the problem.
Typical start circuit...
Diagram courtesy of Tmoss &Stang&2birds
From your last post, the starter is dragging, or it is a miswired mini starter.
P
PJB
131
Rotterdam, NY
Oct 13, 2007
  • Oct 13, 2007
I did find out its definately not the ignition switch after replacing it (didnt see your post before I went and got it).
Its not a mini starter so I can rule that out.
Should I just replace the starter? Id hate to spend $100 on a part that might or might not fix the problem.
MahFiVeOh
531
9
49
Ontario, Canada
Oct 13, 2007
  • Oct 13, 2007
It seems like this is happening alot lately.I had the same issue last year.
Check your PM's PJB.
HISSIN50
34
129
Oct 13, 2007
#10
  • Oct 13, 2007
  • #10
If you have a stick, a bad ignition switch will likely show up as having the starter re-engage when you depress the clutch pedal. Otherwise, the start signal doesnt get past the Clutch safety switch.
That said, replacing the ignition switch is normally never a bad thing.
I second getting more info on your exact starter set-up and how it's wired. Are there any funny noises when it happens? Is the starter bolted in tight? Do you have an extra motor ground? If not, Jrichker can tell you how to do it - having grown up in rain and snow country, I can tell ya how many issues arise from bad ground pathways when it's wet outside.
Good luck.
P
PJB
131
Rotterdam, NY
Oct 14, 2007
#11
  • Oct 14, 2007
  • #11
I dont have a clutch so thats not it (aod car).
My starter is the stock one and is wired up the stock way.
As far as I know the bolts are tight but Ill double check them just in case tomorrow.
Theres really no funny noises except the spinning of the starter motor when this happens. No knocks, clunks, clicks, etc.
Im pretty sure the grounds are all where theyre supposed to be.
A
andyctgt
Banned
Apr 25, 2007
10
#12
  • Oct 14, 2007
  • #12
my car did this about a month ago and it was the negative battery cable, like u said all grounds apeared to be ok, but someone suggested this to me as the problem so i changed the wire ,and the car fired right up and the starter turned off like it is supposed to.
baldy1
124
Portsmouth Va
Oct 14, 2007
#13
  • Oct 14, 2007
  • #13
Dude change the starter. Jrichker is right look at the wiring diagram. It tells you there. He is the man when you have an electrical prob
P
PJB
131
Rotterdam, NY
Oct 15, 2007
#14
  • Oct 15, 2007
  • #14
How hard is it to replace?
P
PJB
131
Rotterdam, NY
Oct 16, 2007
#15
  • Oct 16, 2007
  • #15
I took the starter out today and got it tested.
It tested fine unfortunately.
Now what?
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Oct 16, 2007
#16
  • Oct 16, 2007
  • #16
Fairly easy, I replaced mine in about 30 minutes. The top bolt is a little hard to get to but there's a hole in the inner fender you can stick your arm through to get to it. A mini socket wrench or a swivel head box end wrench really comes in handy for that top bolt but you can do without.
Just remove the passenger side front tire to make it easier and it's a snap
P
PJB
131
Rotterdam, NY
Oct 16, 2007
#17
  • Oct 16, 2007
  • #17
I already got it out but it seems like the starter is ok.
It was fairly easy to get out actually.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 16, 2007
#18
  • Oct 16, 2007
  • #18
A starter with a dragging Bendix that does not disengage will often pass the bench test.
Look at the starter and flywheel gear teeth. Wear on them indicates the starter Bendix
isn't pulling back, allowing the starter to drag and continue to run when the engine fires off.
baldy1
124
Portsmouth Va
Oct 16, 2007
#19
  • Oct 16, 2007
  • #19
You said that when u pull the red/blue wire off the solenoid that the starter kept on turrning. If it does then the bendix in the starter is bad. Just because it checked out fine. Their is a bushing in the nose of the starter if that bushing is worn bad when the starter gear engages it gets caught on the flywheel. I have seen it before. Been there. Change the starter. Then let us know what happened
P
PJB
131
Rotterdam, NY
Oct 16, 2007
#20
  • Oct 16, 2007
  • #20
I didnt know that and apparently the guy at Advance didnt either because he told me there was nothing wrong with my starter.
I really didnt notice any wear on the gear on the starter and couldnt see the flywheel in the position I was in when I replaced the starter.
Of course I put the starter back in the car already.
So is replacing the starter what I should do?
I cant afford to keep throwing parts at this car.
1 of 2 Next Last
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
