Starter problem
  • Thread starter Thread starter MahFiVeOh
  • Start date Start date Sep 23, 2004
MahFiVeOh
531
9
49
Ontario, Canada
Sep 23, 2004
  • Sep 23, 2004
Lately my starter has been acting up, when i turn the key my starter does not want to turn off.I can take the keys right out of the ignition and the starter just screams away.I thought it might be the starter relay so i got a new one, that didnt help.Is my starter shot or maybe the ignition switch? I thought i saw something about an ignition switch recall but i cant be 100% sure.Any ideas on whats going on here? This tends to be embarrasing when people are around
ANy help would be appreciated.
Thx
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 23, 2004
  • Sep 23, 2004
There is a FREE recall on Ford ignition switches. They overheat and sometimes catch fire.
Copy down you VIN number and call the Ford dealer nearest you. Tell them you want to see if the ignition switch recall for Fords & Mustangs was done on your car. They will ask for the VIN number & check it against the master database. If it isn't in the database, then you can schedule an appointment to have the switch replaced for free. The TSB is #95S28, and don't let them tell you that they don't do that anymore...
MahFiVeOh
531
9
49
Ontario, Canada
Sep 23, 2004
  • Sep 23, 2004
bgjohnson
963
johnston,iowa
Sep 23, 2004
  • Sep 23, 2004
or you could have a sticky solenoid or relay.
MahFiVeOh
531
9
49
Ontario, Canada
Sep 23, 2004
  • Sep 23, 2004
I already replaced the relay (the one under the hood on the fender)
Is there one on the starter also?
M
motor
  • Sep 23, 2004
starter relay
Having the same problem with a brand new relay from ford.... I take the relay out of the car and put a meter (continuity test)on it and see that its still in the closed position. Wondering if this is arcing itself to the point where it sticks (slight weld) if so what causes this to happen,,,, a Bad ground????Do you also have the batt in the trunk? I take the relay shake it around and you hear it open and not rattle as much. Put the meter back on the relay and its now open. Put the relay back in the car without the starter wire on just to hear it click open and close when i turn the key, it works fine , put the starter wire back on , give it a 3 second crank and it sticks in the closed position again. Its diving me nuts i have a s-trim now installed and this isue has me at a stand still. Help???????
P.s this also was an isue with my previous relay
MahFiVeOh
531
9
49
Ontario, Canada
Sep 23, 2004
  • Sep 23, 2004
Battery hasnt been moved. Is your starter doing the same thing as mine? It just stays on and screams after you try to crank it over.I noticed if i give the relay a quick tap it seems to fix the problem, only temporarily though.I am going to take this relay back tomorrow just in case it is faulty.
One thing we noticed while trying to figure this out is that my Alt is not charging my battery, i really cant see how this could affect the operation of the starter.
Anyone else have any ideas?
M
motor
  • Sep 23, 2004
I gave the battery a good charge because ive been slacking putting in this strim. and now it seems to be working. I m wondering if the battery wasnt enough to activate the relay all the way to the closed position, which caused it to arc to make up for the gap accross the relay posts inside and created like a welding effect which caused mine to stick hard everytime? Im bringing this relay back to ford, swaping it for a new one then also getting a new battery as im due anyways. try a good charge before going nuts
MahFiVeOh
531
9
49
Ontario, Canada
Sep 23, 2004
  • Sep 23, 2004
I will probably end up getting a new battery also, mine is fairly old.This is making a bit more sense now after hearing that you put a good charge on your battery.I read an old thread that i found when i did a search about an Alt charging problem.The guy wasnt getting a good charge and the low voltage was causing the relay to stick.
Heres what he quoted "I had similar problems with my 3G Alt...I then started killing Starter relays because the low voltage was causing the contacts to weld together during starting (took a couple days each time)...I replace the battery to starter relay with a 2 gauge, the negative battery post to block with a new 4 gauge. Double check your alt to starter relay cable (MUST be al least a 4 gauge) for good connections. Once I replaced those cables and the starter relay....16 volts at battery (just above the middle of the gauge...never drops below that middle mark on gauge by more then a mm or 2, even with the elect fan, AC, lights, and radio on at once sitting a light). Try it. Your wires are probably original and could use being replaced anyway and may save you time and fustration"
http://forums.stangnet.com/showthread.php?t=504161&highlight=starter+problems
I'm crossing my fingers
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
All power lost at crank
  • saf_blu302
  • Mar 7, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Mar 12, 2026
General karthief
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
  • brandyn200
  • Jun 20, 2026
AeroCoupe
