starter problem
  • Thread starter Thread starter fordmuscle395
  • Start date Start date Oct 21, 2008
fordmuscle395
114
Sumter, sc
Oct 21, 2008
  • Oct 21, 2008
as soon as i hook up the battery the starter starts spinning the motor like its trying to crank, the key is not in the ignition...whats going on here
warriorpluto
267
monroe.LA
Oct 21, 2008
  • Oct 21, 2008
starter solenoid. or if you just hooked up a mini starter....could be hooked up wrong.....
fordmuscle395
114
Sumter, sc
Oct 21, 2008
  • Oct 21, 2008
dangit, i just replaced that solenoid! Hopefully thats all it will be...
93 LX
3,081
Norwalk, CA.
Oct 21, 2008
  • Oct 21, 2008
You don't have the battery and starter wire on the same lug do ya?
fordmuscle395
114
Sumter, sc
Oct 21, 2008
  • Oct 21, 2008
nope, i've connected and reconnected the wires on the solenoid like 20 times now
93 LX
3,081
Norwalk, CA.
Oct 21, 2008
  • Oct 21, 2008
if you disconnect the 12 gauge wire (red and green) I think from the solenoid does it still engage the starter?
fordmuscle395
114
Sumter, sc
Oct 21, 2008
  • Oct 21, 2008
theres a blue and red..but thats for the ignition switch. i disconnect it and the starter still turns over when battery is connected
93 LX
3,081
Norwalk, CA.
Oct 21, 2008
  • Oct 21, 2008
one last test. Remove everything except the battery and cable going to the starter from the lugs. If it still spins the starter then you have a bad solenoid.
fordmuscle395
114
Sumter, sc
Oct 22, 2008
  • Oct 22, 2008
....still turns over as soon as battery is connected. gonna replace solenoid with a solenoid thats not made in mexico like the one from auto zone. We'll see how it goes, thanks!
JKidd
164
Suffield, CT
Oct 22, 2008
#10
  • Oct 22, 2008
  • #10
The mini starter has a solenoid on the unit itself (as well as the one mounted near the battery in the engine compartment). THAT is the solenoid that might be toast. Gotta replace the starter if that is the case.
Same thing happened to my previous '92 LX as well as my new '92 LX earlier this summer.
fordmuscle395
114
Sumter, sc
Oct 22, 2008
#11
  • Oct 22, 2008
  • #11
k now im really lost. I replaced the solenoid connected the battery..and it dident turn over. so went to crank it....it started but i heard the starter still engaging. so i turned off the key and the starter kept going, again.
I installed a 130amp alternator with a 4ga power wire before all this crap started happening. Could the extra output at start be screwing up my solenoid?
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
Electrical Starter solenoid green wire?
  • 387lx
  • Jun 1, 2026
Fox 5.0 Mustang Tech Jun 2, 2026
AeroCoupe
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
