  • 1994 - 1995 Specific Tech
starter problems
  • Thread starter Thread starter urban96
  • Start date Start date Sep 24, 2005
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Sep 24, 2005
  • Sep 24, 2005
well tonight i went to start up the car but it wouldnt turn over
battery showed good voltage, even tried to jump it but it wouldnt turn over
i can crank it over by hand so i know things are moving freely in there
the first time i tried it clicked twice and the rest of the times got nothing... its a bran new starter too(only had it for about a month) did i blow some kind of fuse? i dont even know where to start looking
HISSIN50
34
129
Sep 24, 2005
  • Sep 24, 2005
Do your headlights stay nice and bright for 30 seconds or so?
One can use a jumper cable to augment a ground or the power connection to the distribution block (be real careful with the latter).
Since you get a little chunking noise, the starter interlock (clutch safety switch/neutral safety switch) should be passing current.
Good luck.
urban96
3,464
Syracuse, NY
Sep 24, 2005
  • Sep 24, 2005
Good luck.
well my car came with an auto in it and theres no more neutral safety switch
it worked the other day i think tis either a bad connection or a fuse.. what fuses deal with that?
i was pulling my drivers side valve cover and had disconnected the alt to get a lil more clearence and i didnt notice the negative batt connection was touching and got a nice lil spark show but it was from the alt wire to the alt
HISSIN50
34
129
Sep 24, 2005
  • Sep 24, 2005
Sorry - the crystal ball in my avatar must not be working very well.
The alt has like a 20 amp fuse in the underhood fuse box and there is a starter relay IIRC in the same underhood fusebox. I dont recall a specific fuse just for the starter, nor would you be getting any noise when trying to start, if it blew.
I would have to look at some schematics to find more. gotta go eat dinner.
Good luck.
urban96
3,464
Syracuse, NY
Sep 24, 2005
  • Sep 24, 2005
thanks
i hate all these stupid lil problems
94Blue302GT
704
Chicago
Sep 24, 2005
  • Sep 24, 2005
you might also want to check the relay in the high amp fuse box. you can check it by switching it with the one for your fog lights. see your owner's manual to see the locations.
urban96
3,464
Syracuse, NY
Sep 25, 2005
  • Sep 25, 2005
figured it out, it was a bad ground...
ran a ground from one of the starter bolts to the chasis and it worked
HISSIN50
34
129
Sep 25, 2005
  • Sep 25, 2005
Nice work. Upgrading the motor to chassis ground should help as well.
Good luck.
Paristic draw?
  • Creomod
  • Thursday at 4:31 PM
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 11:34 AM
General karthief
M
2004 v8 convertible
  • Mikeycrownvicluver
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
Mikeycrownvicluver
M
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
