starter problems
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
well tonight i went to start up the car but it wouldnt turn over
battery showed good voltage, even tried to jump it but it wouldnt turn over
i can crank it over by hand so i know things are moving freely in there
the first time i tried it clicked twice and the rest of the times got nothing... its a bran new starter too(only had it for about a month) did i blow some kind of fuse? i dont even know where to start looking
Do your headlights stay nice and bright for 30 seconds or so?
One can use a jumper cable to augment a ground or the power connection to the distribution block (be real careful with the latter).
Since you get a little chunking noise, the starter interlock (clutch safety switch/neutral safety switch) should be passing current.
Good luck.
Good luck.
well my car came with an auto in it and theres no more neutral safety switch :shrug:
it worked the other day :shrug: i think tis either a bad connection or a fuse.. what fuses deal with that?
i was pulling my drivers side valve cover and had disconnected the alt to get a lil more clearence and i didnt notice the negative batt connection was touching and got a nice lil spark show but it was from the alt wire to the alt
Sorry - the crystal ball in my avatar must not be working very well. :rlaugh:
The alt has like a 20 amp fuse in the underhood fuse box and there is a starter relay IIRC in the same underhood fusebox. I dont recall a specific fuse just for the starter, nor would you be getting any noise when trying to start, if it blew.
I would have to look at some schematics to find more. gotta go eat dinner.
Good luck.
urban96 said:
figured it out, it was a bad ground...
ran a ground from one of the starter bolts to the chasis and it worked
Nice work. Upgrading the motor to chassis ground should help as well.
Good luck.
