Starter Question
  • Thread starter Thread starter bull999999
  • Start date Start date Jul 17, 2004
bull999999
112
  • Jul 17, 2004
Will a starter from 88 Bronco with 5.0 and 5 speed work on a older 289/302 engine with a C4?
R
Ronstang
1,294
Houston Texas
Jul 17, 2004
  • Jul 17, 2004
All small block starters should be interchangeable if I remember correctly. The wiring may be slightly different but that should not be a problem at all.
67coupestang
509
  • Jul 18, 2004
ummm some of them are built to engage the flywheel deeper. just pull the old stang one and compare it to the bronco one.... Pay attention to how far the horn around the gear sticks out on both.
D
D.Hearne
11,730
south louisiana
Jul 18, 2004
  • Jul 18, 2004
Also count the number of teeth on the gear, there were 2 different tooth counts over the years.
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
H
1966 mustang starter and pulley troubles
  • Hotrods4ray
  • Sep 24, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 10, 2026
Realmongo
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
Engine Starter ring gear depth. 3/8 or 3/4 inch?
  • 92Rustang
  • Aug 4, 2025
Fox 5.0 Mustang Tech Aug 22, 2025
Rcdgl
R
