Starter question
SMOKEDYA
Jul 13, 2003
3,637
Tucson AZ
So i hide all my wireing and did the battery relocate to the trunk. I've had a couple of months with no problems. then last weekend went to a show and came home. Later that night i went to go somewhere and it sounded like i had a dead battery or bad starter sylnoid it made a really fast click click click? So i started checking everything and after i kept trying to start it there was like no power period to the car? So i tried to jump it and still no power? So i started trouble shooting and came to the conclusion the battery cut off switch was bad? I bypassed the switch and it started and ran fine, then lastnight i went to get the kids and i started it and let off the key (cause my hand slipped off the ign.) then tried it again and nothing no power again? So i got to the trunk checked the fuse (150AMP)and it had blown? So i bypassed the fuse and it started. So could i have a bad starter and that might be causeing these problems? I just put a new starter sylinoid on when i did the wire hidding. I beleive it has a mini hi TQ starter, atleast my buddy seems to think that? From the day i got the car its always seem to turn over slower then my 95 has? So if i got a better quality fuse would that help? It looks to be a nice one from a stereo shop, i can post pics tonight or toorrow night of the fuse. I'm not shorting out on anything either i've checked all the wireing. peace
john:p
There should not be a fuse in the wire that goes to the starter solenoid from the battery. A 3G alternator needs a fuse in the 4 gauge wire from the alternator to the starter solenoid.
Rear mounted battery ground wiring. Follow this plan and
you will have zero ground problems.
One 1 gauge or 1/0 gauge wire from battery negative post
to a clean shiny spot on the chassis near the battery. Use
a 5/16” bolt and bolt it down to make the rear ground.
Use a 1 gauge or 1/0 gauge wire from the rear ground
bolt to a clean shiny spot on the block.
One 4 gauge wire from the block where you connected
the battery ground wire to the chassis ground where the
battery was mounted up front. Use a 5/16” bolt and bolt
down the 4 gauge engine to chassis ground, make sure
that it the metal around the bolt is clean & shiny. This
is the alternator power ground.
The computer has a dedicated power ground wire with
a cylindrical quick connect (about 2 ½”long by 1” diameter.
It comes out of the wiring harness near the ignition coil &
starter solenoid (or relay). Be sure to bolt it to the chassis
ground in the same place as you bolted the alternator power
ground. This is an absolute don’t overlook it item for EFI cars
Picture courtesy of timewarped1972
attachment.php
Crimp or even better, solder the lugs on the all the wire.
The local auto stereo shop will have them if the auto parts
store doesn't. Use some heat shrink tubing to cover the lugs
and make things look nice.
For a battery cut off switch, see http://www.moroso.com/catalog/categorydisplay.asp?catcode=42225
is the switch http://www.moroso.com/catalog/images/74102_inst.pdf is the installation instructions.
Use the super duty switch and the following tech note to wire it and you will
be good to go.
Use the Moroso plan for the alternator wiring and you risk a fire. The 10
gauge wire they recommend is even less adequate that the stock Mustang
wiring.
There is a solution, but it will require about 40' of 18 gauge green wire.
Wire the battery to the two 1/4" posts as shown in the diagram.
The alternator requires a different approach. On the small alternator plug
there is a green wire. It is the sense lead that turns the regulator on when
the ignition switch is in the run position. Cut the green wire and solder the 40'
of green wire between the two pieces. Use some heat shrink to cover the
splices. See http://fordfuelinjection.com/?p=7 for some excellent
help on soldering & using heat shrink tubing.
Run the green wire back to the Moroso switch and cut off the excess wire.
Try to run the green wire inside the car and protect it from getting cut or
chaffed. Crimp a 18 gauge ring terminal (red is 18 gauge color code for the crimp
on terminals) on each wire. Bolt one ring terminal to each of the 3/16" studs.
Do not add the jumper between the 1/4" stud and the 3/16" stud as shown it the
Moroso diagram.
How it works:
The green wire is the ignition on sense feed to the regulator. It supplies power
to the regulator when the ignition switch is in the run position. Turn the
Moroso switch to off, and the sense voltage goes away, the voltage
regulator shuts off and the alternator quits making power.
See the following website for some help from Tmoss (diagram designer) &
Stang&2Birds (website host) for help on 88-90 wiring and lots more…
Diagram courtesy of Tmoss and Stang&2birds.
