Starter question??????
  • Thread starter Thread starter SMOKEDYA
  • Start date Start date Aug 26, 2006
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Aug 26, 2006
  • Aug 26, 2006
Hey i'm doing a swap with a 95 engine into a 88 gt. Now i'm to the point to were i have to hook up the starter, so the 88's has just one wire (+) but it wont fit into the 95's hole for it in the bell housing. That is why i'm using the 95's. So on the 95 starter there is a power wire and another wire, were can i run this other wire from the 95 starter to? I thought it would just be a ground but that didnt work? The starter solinoid on the driver side fender just clicked? Could it be that i ran to small of a gauge wire or does it go to the other side oposite of the + on the solinoid? I have this set up on my 93 buti hide all the wires and the solinoid in the fender and cant see where it goes? peace
john
Hickfied
413
Morganton, NC
Aug 26, 2006
  • Aug 26, 2006
I am not sure, but I think I heard that the 94 and 95 starters had a built in solinoid.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Aug 26, 2006
  • Aug 26, 2006
Damn so now what? Just run thepower wire to it? here is a pic of mine wheni hide all the wires, but as far as i know it's not a 95 starter but it is the same set up. I was told mine is a mini high tq starter?:
if you look at the wire loom on the far left you can see the black wire comming out of it, thats the wire comming off my starter and looks to go to the other side of the solinoid? What do you guy's think? peace
john
Fett
766
  • Aug 26, 2006
Imagine how the 88 was setup. You should have had one 4 gauge wire going from the front (towards the car) post on the fender solenoid, that went down to the starter. Well you will still have that wire from the starter, but this time you will move it from the front post on the solenoid to the + post on the battery itself. Now you need to run a trigger wire from the front post on the solenoid down to the "extra" terminal on the starter. The 95 starter has it's own solenoid built it. So the starter should get the 4 gauge wire hot at all times, and the trigger wire only comes on to....well, trigger the starter when you turn the ignition.
The added benefit of this is you won't ever have to deal with the fender solenoid fusing itself and constantly trying to turn the starter....which a lot of people have to experience from time to time. Which is why I upgraded to the 95 starter in my 88 motor.
Electrical Starter solenoid green wire?
  • 387lx
  • Jun 1, 2026
Fox 5.0 Mustang Tech Jun 2, 2026
AeroCoupe
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
