OK, I got my wiring diagrams. They are for '03, but I expect '04 should be identical. Forget most of what I wrote above; it is probably wrong
There are 2 fuses that protect the starting system. One is located near the battery, and the other on the underside of the instrument panel.
The fuse near the battery is labeled "starter relay & ignition" and is supposed to be 40A. If that's the fuse that is blowing, my previous message applies.
The fuse under the I/P is supposed to be 20A, and labeled "starter relay & radio". It protects the circuit that powers the relay coil. A red / blue stripe wire runs from the fuse to the clutch switch (manual transmission) and park/neutral switch (automatic transmission). From there, a white / pink stripe wire runs to the starter relay coil.
I have seen a previous message on Stangnet where one of the pedal arms chafed a wire and caused a short, so that is the first place I would look. A/T cars have a jumper in place of the clutch switch, and M/T cars have a jumper in place of the transmission park/neutral switch.
While a shorted relay coil is a possibility, this to me would be rare. You can remove the relay and check the coil resistance with an ohmmeter. It should be no less than 25 ohms.
