  • SN95 4.6L Mustang Tech
Starter Removal
  • Thread starter Thread starter Jagbag
  • Start date Start date Mar 2, 2009
J
Jagbag
  • Mar 2, 2009
I'm currently trying to replace my starter on my "99 GT, and have run into a small hickup if you will. There are three bolts that hold on the starter and I can only get to one of them. Does anyone know how to access the other two. The two that I cannot get to or even feel are the one on the top and the one on the passenger side of the car. There is only a small opening to fit your hand up in there to get at the starter. I've tried taking off the passenger side front wheel and still cannot see the bolts I need to get at. Is there some sort of trick to this or what am I missing here.
Any help would be much appreciated!!! Thanks.
Jag.
mogs01gt
3,113
30
119
Ohio
Mar 2, 2009
  • Mar 2, 2009
Yep, you have to go through the engine mount on the K-member and use about 3.5ft of extensions with swivel on the end. You do not need that top bolt. I havent had three starter bolts on my car for years.
J
Jagbag
  • Mar 2, 2009
Thanks so much for your help...I'll try that out this weekend.
mogs01gt
3,113
30
119
Ohio
Mar 2, 2009
  • Mar 2, 2009
Buy a new swivel to. A warn out one will just collapse as you are running it through. Or use the old trick and tape the swivel so it stays firm.
Shiroelex
There's nothing worse than aut
728
Westland, MI
Mar 2, 2009
  • Mar 2, 2009
+1 on the tape trick. I ended up using a quarter inch drive socket, swivel, and extensions with a 3/8 adapter and ratchet. Worked out pretty well.
Electrical Mini-Starter Wiring
  • RekeHavoc
  • Jul 25, 2025
2K
Fox 5.0 Mustang Tech Aug 24, 2025
Mustang5L5
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
  • Gulftown980x
  • Jul 29, 2026
squeak93
