Starter won't START!!!
lawrence
243
San Francisco, CA
What are the odds that starters are being killed off by my mustang. Not 3 months ago, I had a new starter put in my car, and now the stupid thing is not starting again. Maybe after 15 minutes and some luck, the car finally will turn over and start.
Whats going on here? Would my stereo amp be a problem? I haven't changed anything in the car that I can think would cause this problem? Could it be the distributor or plugs? Wires? Any suggestions. All electronics work, but the stupid thing is just stubborn to turn over.
Cranks OK, but No Start Checklist.
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) Coil
B.) TFI module
C.) PIP sensor in distributor
D.) ECC relay next to computer
E.) Fuse links in wiring harness
F.) Ignition switch
G.) Computer
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
3.) Spark at spark plug, but no start. Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off.
Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out. Beware of fire hazard when you do this.
No fuel pressure, possible failed items in order of their probability:
A.) Tripped inertia switch – press reset button on the inertia switch located by driver’s side rear shock absorber. Most of the time, you can remove the plastic access cover over the shock absorber top mount to get at it. Use the voltmeter or test light to make sure you have power to both sides of the switch
B.) Fuel pump power relay – located under the driver’s seat in most stangs built before 94.
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness.
4.) Spark & fuel OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
B.) Failed computer ( not very likely)
I turn the key, I hear the fuel pump prime up for about 10 seconds, and I hear the click of the solenoid? or plugs? But the engine does not turn over. The car is not totally dead, cause eventually it will kick over very lazy and finally start. This has taken as little as a minute, and as much as 15 minutes, of intermittent turns of the key. Electronics all turn on. Sound like a spark plug or something?
Jason, that looks like Joe's list.
turn key to on, car in neutral (if manual trans).
jump the small slide-on-terminal on the top of the solenoid to the battery side of the solenoid (has all the connections on it). if car starts, problem with wiring from ignition to solenoid (at ignition switch, neutral safety switch, clutch safety switch, wire itself etc).
if no luck, jump the two big lugs of the solenoid using a big screwdriver, etc. if it starts, bad solenoid.
good luck
JasonMonette said:
It is the list that I was given when I was having trouble with my car starting. I kept it for a reference. I am not sure who was kind enough to give it to me, but I thought I would share it and help somebody else out.
that's cool. i was kinda kidding. it came from Jrichker. i understand now, that you didnt know whose it was, otherwise, you would have given him credit.
cool.
Well, I got the stang started after removing the negative terminal from the battery, but then later that day it was not starting again. Oh well, I'm just gonna get it started and take it over to the mechanic. I'm in an apartment, and it is too difficult to work on the car here, not to mention I need the car for driving on Monday.
Thanks guys.
Thanks guys.
Don't cave!!! Seriously, if you follow that check list I gave you above, you will find the problem!!!
When my car wouldn't start it was cause the Nuetral Safety Switch wire was rusted through. A simply wire, cause all my problems.
