Starter
  • Thread starter Thread starter SteedaGT9150
  • Start date Start date Apr 13, 2005
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Apr 13, 2005
  • Apr 13, 2005
how hard is it to put in a starter? any tips? thanks
NKau
1,346
Jefferson, WI
Apr 13, 2005
  • Apr 13, 2005
Fairly easy. If you have longtube headers, it's a little more difficult. There are just two bolts that hold it in. The top bolt can be a pain to reach; I recall using a fair amount of extensions to get the socket past my header tubes (longtube headers).
whitehorseupnorth
SSoM President
1,772
Maine
Apr 13, 2005
  • Apr 13, 2005
Not hard at all. Just a pain to get to the top bolt. Also the top one likes to get seized in there sometimes. It gets kind hot from the header being right there. Having 2 disimiliar metals doesn't help matters much either.
kornchild4life
46
islip, ny
Apr 13, 2005
  • Apr 13, 2005
i had to change my starter like last week or so, its not too hard to change just a pain to get the top bolt out i had to take off the passager side tire and unively(spell check) joint shocket to get to the bolt. if it was for that i would have been cursing a lot more and breaking something good luck with yours
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Apr 13, 2005
  • Apr 13, 2005
ARP Starter Bolt Kit - ARP-450-3501
That is if you want to replace the bolts when you do it.
Just two bolts and undo the electrical connections and you will have it off. Installation is the reverse of removal and that is that.
Some people put in mini-starters for better torque (starting torque/not engine torque) and a smaller size so they aren't so susceptible to header heat...
Good Luck
(Jack up the car safely when attempting the starter removal - your body will thank you later)
J
jerry beach
2,671
Ocala,FL
Apr 13, 2005
  • Apr 13, 2005
about 2 feet of extentions and right in next to the motor mount. Thats how you loosen the top bolt. Otherwise its pretty simple. Get a manual and read it, it will give you some good info. Reading and understanding the proceedure before hand can make your life easy. A starter is simple to some and others dont know how easy it can be to twist the starter wire terminal and ruin it.
squeeeg
1,905
Michigan
Apr 13, 2005
  • Apr 13, 2005
It is real easy. Definately something to do yourself. TIP: use a gear wrench for the top bolt or lots and lots of extentions.
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Apr 14, 2005
  • Apr 14, 2005
k thanks thats one of my things to do on saturday i saw where it was and thought it would be a pain to get to thanks.
squeeeg
1,905
Michigan
Apr 14, 2005
  • Apr 14, 2005
You are going to scrape your hands up a little but you should be fine.
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
Electrical Starter solenoid green wire?
  • 387lx
  • Jun 1, 2026
Fox 5.0 Mustang Tech Jun 2, 2026
AeroCoupe
Electrical Mini-Starter Wiring
  • RekeHavoc
  • Jul 25, 2025
2K
Fox 5.0 Mustang Tech Aug 24, 2025
Mustang5L5
Engine Starter ring gear depth. 3/8 or 3/4 inch?
  • 92Rustang
  • Aug 4, 2025
Fox 5.0 Mustang Tech Aug 22, 2025
Rcdgl
R
Electrical Defrost switch ignition?
  • Teen'93stang5.0
  • May 16, 2026
Fox 5.0 Mustang Tech Jun 3, 2026
Teen'93stang5.0
