well, its time to up the ante`.
ive enjoyed the turbo 4v. now that i have the 2011gt, i can build the teksid 4
v for some REAL power.
i just bought some 4340 I-beam CNC billet rods. haven't picked the pistons yet. they are definitely going to be 3v pistons in case i switch to 3v at some point. i already have a 04 cobra crank. gotta get it rebalanced. these rods are lighter than stock 04 cobra rods. im gonna look around for a lighter crank that can take the power. ill use the cobra crank if i cant find one.
i dont need to sump the gas tank. granitelli sells a AN-10/8 fuel hat. its enough with an a1000 pump. gotta change to a firewall regulator. using the cobra fuel rails i have.
gonna up the compression ratio from 8.5:1 to 9:1. gonna limit it to 6500 this time. i have been shifting it at 6900-7200. stock cams retimed should still be enough. might change to bigger cams if i need to. i am definitely quitting after this. 1k is enough. turbo has not been selected yet (72-76mm is required) . gonna redo the exhaust crossover for larger cross section. going to 2 3/4" primary tubes, 4" oval under the k-member and 4" after turbo. just shorty headers feeding the cross over.
intake and heads are already good for 1000hp. intercooler and piping is already rated for 1000hp. gonna boost the hell out of it.
