Starting Issue - 97 GT
tempus
Need some asssitance with a starting issue on a 1997 GT wit 150,000 miles. The car will turn over and immediatly shutdown. If I give the car gas it will start up and stay started until I remove my foot from the gas and then it shuts down. I just changed the fuel filter and checked the fuel pump fuse and I am still getting the same issue. Could it be the fuel pump?
Any help would be appreciated. Thanks.
Thanks for the info. It took a little bit more items to make it work. I am guessing I should have done some premptive maintenace over the years. Here is what I replaced and had to get replaced:
-Idle air control sensor
-Fuel Filter
-EGR Valve
-Some Vacum hoses
-Mass Air
-Oxygen sensors
Hopefully, I will be good for another 150,000 miles.
