Okay guys, now that I'm home I have time to actually read your posts, lol.
Urban, the cables were all good, and the (I'm assuming you're talking about the starter motor) motor was good.
Scott Scott (
), like I said, the cable was good, and I charged the battery at 50 amps, so it charged pretty quick. We also set it to jump (225 amps) and it still wouldn't start. So I know it wasn't the battery.
Joe, I was seeing 12.8v or so IIRC on the battery by itself. With the jump box hooked up, it shot up to around 14v!! Oh, and that plug was good, on my new starter, it's a ring terminal connection, I had to cut the plug itself off and put a terminal on it.
JT, HAH!!! 10 volts!! It dropped to like
1 volt when cranking! lol. I did jump the two terminals (boy that was a PITA with it installed, lol), still no go.
Wanna hear something funny guys? I had a friend check the voltage at the starter while cranking, and he had me hold it for a bit in the crank position, all of the sudden smoke starts pouring in from my center console! With the bad ground, the electricity was finding an alternative ground, my ebrake cable!! It was glowing orange!!
It burnt the boot off it underneath the car, and charred the cable white. It's a lot easier to pull now, I'm sure it will break soon now, lol.
I also took my ignition cylinder out thinking that might be the culprit (as it's busted up). Well it wasn't, and in the process I dropped it on the floor and a few springs and pins came out. I couldn't get it back together so I said fawk it, I'll buy a new one. Nope JT, the whole thing's broke! Oh well. So right now my steering column is torn apart until I get a new cylinder, lol. Makes it easy to steal my car I'm sure.
