You have a bad ground on the negative cable. Clean the cable connection where it bolts to the block down by the oil filter. If you have the battery post clamps that use 2 bolts to clamp onto the cable ditch them and get a real ground cable. Make sure you connect the computer ground pigtail to the battery ground when you replace the cable.
The computer has its own dedicated power ground that
comes off the ground pigtail on the battery ground wire. Due to
it's proximity to the battery, it may become corroded by acid
fumes from the battery. It is a black cylinder about 2 1/2" long
by 1" diameter with a black/lt green wire. You'll find it up next to
the starter solenoid where the wire goes into the wiring harness
The battery common ground is a 10 gauge pigtail with the computer ground
attached to it. The picture shows the common ground point for the battery to the body.
Picture courtesy timewarped1972
Some diagrams just in case you crossed some wires...
Starter solenoid wiring for 86-91 Mustang
Starter solenoid wiring 92-93 Mustang or upgraded high torque mini starter.
