Starting problem
gt500lw
18
Hey! Ok, so I start my '87 coupe, only to have it die. I do this over and over. The only way to keep it running is to play with the throttle. After driving it for about a mile it will stay running, and runs well. It was recently in the shop for unrelated problems, but they had test the fuel system and said it was fine. I am a little confused, please help. Thanks :flag:
I had a similar problem with my 89. I went through all the "rough" idle cleaning steps, reset TPS, everything to no avail. Turns out my PCV valve wasn't functioning, my hose came unhooked. Once the hose was back in place my car starts up fine. I only had trouble on cold starts though. Just an idea
I would clean the IAC and perhaps reset the idle settings if you have reason to think they are bad.
Good luck.
