starting problem
  • Thread starter Thread starter JimmyRGT
  • Start date Start date Dec 21, 2005
JimmyRGT
118
Atlanta, GA (GA Tech)
Dec 21, 2005
  • Dec 21, 2005
Hey guys, havnt been here in a while but now im back. So im driving the car today (its a 95 GT) and it has been running fine. Only unusual thing is that recently when i start it cold it had a small delay before it started up. By that i mean i would turn the key, and there would be silence then about 1-2 seconds later it would start cranking and start up. Tonight however I pulled into a gas station, cut it off, came back out, and it wouldnt start. It cant turn over. It tries to turn over the first time but makes it about half way through and then stops. It is also making a squeaking/whiny sound when i try to start it. I dont know what the problem is. Could it be the starter? Alternator? I am stumped right now. I have ruled out the battery however. I appreciate any and all advice.
Jimmy
P
PRO50SC
1,012
Olney, Maryland
Dec 21, 2005
  • Dec 21, 2005
Check the connections. How have you ruled out the battery?
JimmyRGT
118
Dec 21, 2005
  • Dec 21, 2005
Which connections? I ruled out the battery by first trying to have it jumped off, and then having my brother come up who also drives a mustang, and puting his battery in my car. Same problem remained.
1SLO306
My 97 GTP owns you ALL!
Mar 31, 2005
904
Muhlenberg, ky
Dec 21, 2005
  • Dec 21, 2005
does it sound like the starter is just spining???if so it could have possibly worked loose or u have a bad spot on the flywheel. just my .02 tho
JimmyRGT
118
Dec 21, 2005
  • Dec 21, 2005
It sounds like the car wants to start but cant turn over the first time. It also makes a squeaking sounds while it tries to start. By turn over i mean that womp womp sound it does before it starts every time. It makes it through half a womp, then stops. Im lost.
bill302
2,131
alabama,gadsden
Dec 21, 2005
  • Dec 21, 2005
check for broken,loose or disconnected wiring in starting circuit . inspect all wiring and connectors at battery, starter solenoid and ignition switch. if all connections are tight with no breaks. i would remove starter and have tested at parts store. sounds like solenoid to me.
1SLO306
Mar 31, 2005
904
Muhlenberg, ky
Dec 21, 2005
  • Dec 21, 2005
:Word: the selinoid has been a biotch to me on my car
if all them are fine and the test comes back good i would take the belt off and see if any of the pulleys are locked. my p/s pump locked up and kinda did the same urs is doing also
gwhiz50
95
San Antonio, TX/Retire in Colorado Springs, Co
Dec 21, 2005
  • Dec 21, 2005
That is same symptons I was having with the starter on my truck. It will go completely if you don't get it fixed now.
HISSIN50
34
129
Dec 21, 2005
  • Dec 21, 2005
If not mentioned, I would go over all the primary battery connections. One can use a jumper cable in parallel with a given cable and then try starting the car. If the issue subsides, the cable that the jumper is paralleling is likely not up to par.
Dont forget the motor ground, etc (the starter achieves ground via the motor's ability to be grounded).
Good luck.
JimmyRGT
118
Dec 21, 2005
#10
  • Dec 21, 2005
  • #10
Ok its woo late for me to test anything tonight, but i did try to pinpoint the squeak and it sounded like it was coming from the power steering/ Ac pump area...I will test the pulleys tommorow and then i guess try to get the starter tested. Where could I go to get the starteer tested?
Thanks for all the help guys...
1SLO306
Mar 31, 2005
904
Muhlenberg, ky
Dec 21, 2005
#11
  • Dec 21, 2005
  • #11
i think any shop will do it. let us know how things go tomrrow
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
Resolved Crank no start after engine swap
  • biggrim
  • Sep 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 12, 2026
biggrim
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
