starting problems
demon40
69
canton, nc
ok so my car wont start. I moved the battery to the trunk. It has a brand new ground to the frame from the battery, a power wire from the battery to the under hood fuse block and one straight to the starter. the original battery ground was attached to the frame and i ran another ground from the alternator to the frame. It has been like this for 4 months and just all of a sudden it wont start. So i replaced all the cables (2ga), the starter, the battery, the switch and the relay and the car still wont start. So i pulled every fuse that the car doesnt need to start or run and it still wont start. It will try to turn over but its like the starter isnt getting enough power. If any one has any ideas it would be greatly appreciated.
Thanks in advance
Brandon
