Engine Starts then stalls Surging idle
  • Thread starter Thread starter Luisr010
  • Start date Start date Jun 19, 2023
First Prev 2 of 2
Mustang5L5
Mod Dude
Feb 18, 2001
43,304
18,009
224
Massachusetts
Jun 20, 2023
#21
  • Jun 20, 2023
  • #21
AeroCoupe said:
@Mustang5L5 - I believe his car is a mass air conversion so is there anything with that that would trip a Code 95? The smoke test is a great suggestion.
WHen doing a MA conversion, if you do not add a wire from pin 19 to the fuel pump relay, you will always get a code 95. The speed density cars didn't monitor, so that wire needs to be added. Vast majority of MA conversion articles omit this part (and wiring up the VSS)
If the pump cycles when you pull the codes, it obviously is a false code.
Reactions: AeroCoupe
JAA
5 Year Member
Oct 2, 2018
674
110
63
Central MA
Jun 20, 2023
#22
  • Jun 20, 2023
  • #22
Smoke test
Base idle reset. I like this one: https://stangnet.com/mustang-forums/threads/base-idle-reset.918550/post-9346928
L
Luisr010
Miami, FL
Jun 20, 2023
#23
  • Jun 20, 2023
  • #23
JAA said:
Smoke test
Thank you I will do a smoke test once more and see again for vaccum leaks. Will report back tomorrow.
Reactions: General karthief
First Prev 2 of 2
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
  • dan50
  • Jul 18, 2026
dan50
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
