After a ton of help from you guys and some major setbacks, I went to start her up and there is no power to the EFI pump. I am told that when the key is on there should be a 5 second cycling of the pump then it should shut off. I metered the terminals just as the key was turned on and there is no power.
I wonder if the computer has power? or the fuel pump relay? How do I check? I would assume the first step is to get a reading at the relay, if that is a no go, then how do I check for power at the computer?
All the old wiring/devices/lights work, the dash lights work, fuel sender is reading, I am getting spark to the spark plugs, and the engine turns over without a problem...
But I am heading over there now.
