  • SN95 V6 Mustang Tech
Steeda Vs. Eibach Prokit
  • Thread starter Thread starter juice05
  • Start date Start date Nov 24, 2004
J
juice05
  • Nov 24, 2004
Hello, I was wondering if anyone can help me on lowering springs? I read up on Eibach and Steeda they both declare good hanfdling and a better ride. Only the Steeda lowes the car an inch and the Eibach lowers the car about 1.5 inches, so my question which is better is there any preferances? Also would it be necessary to change shocks and struts too? I'm in college and have a budget to work with, any advice would be thankful.
Thanks
Ernad
celibate sans pants
Apr 2, 2004
Grand Rapids, MI
Nov 24, 2004
  • Nov 24, 2004
You should change your Struts/Shocks when you lower your car. The Tokico Mach 1's are popular.
Another advice is to get an alignment after 1 to 2 weeks after lowering the car.
Now, which is better? I don't know. Just do a search in here on both and you should find some comments to work with.
J
juice05
  • Nov 24, 2004
K thanks.....Where can I find the Tokito MACH 1s? Any good websites?
D
Darkhorse845
Banned
Nov 17, 2004
101
Las Vegas,Nevada
Nov 25, 2004
  • Nov 25, 2004
Welcome to Stangnet! Get a Eibach Pro Kit! They make great quality springs!
J
juice05
  • Nov 25, 2004
K thanks ill look into that ....
97WhiteStang
43
Vienna, VA
Nov 25, 2004
  • Nov 25, 2004
i just got the "c" springs from FRPP and i couldnt be happier with them. and on-sale @ mustangtuning.com for 130 how could u go wrong
D
Darkhorse845
Banned
Nov 17, 2004
101
Las Vegas,Nevada
Nov 25, 2004
  • Nov 25, 2004
The FRPP "C" Springs are nice also!
SpectorV
1,872
Florence, Alabama
Nov 26, 2004
  • Nov 26, 2004
DO not waste your money on steeda springs, dont get me wrong they are a great spring and do good things.... but... the ford C spring is identical to the steeda's and heck probably even gives a little more of a drop for FAR less of a price, the c springs are 100 bucks...
If you go more than 1.3 inchs you will run into alignment issues and strut/shock wearing out faster
SpectorV
1,872
Florence, Alabama
Nov 26, 2004
  • Nov 26, 2004
If you drop your car more than 1.3 inch go with H&R they are very good springs, and if you do go with more than 1.3 inches of drop you will need cc plates along with a set of struts/shocks (they will be fine for a bit but... they will wear out alot faster than a 1.2 inch or so drop so just remember sooner or later they will need replacing)
if you want good handeling get a 600+ rate spring for the front AT LEAST some eicachs are around 450... which is sad when it comes to handeling springs.
Ernad
celibate sans pants
Apr 2, 2004
Grand Rapids, MI
Nov 26, 2004
#10
  • Nov 26, 2004
  • #10
Thanks
BTW the 05 in your name, does that mean you have a new 05? If so, then I would not obey to what any of us said because your car has quite a different suspension setup being a 'new' line of 'Stangs. If not, then never mind.
SpectorV
1,872
Florence, Alabama
Nov 26, 2004
#11
  • Nov 26, 2004
  • #11
definatly if you have a new stang its all out the window.
F
frozgt
21
#12
  • Nov 27, 2004
  • #12
I have owned 2 mustangs and the FMS-C springs and the steeda springs are not the same springs. The height and ride are totally different. I perferred the steeda ride. Remember, you pay for what you get.
Stang|ess
seeking cyber partner(s)
Oct 18, 2003
941
Hawaii
Nov 27, 2004
#13
  • Nov 27, 2004
  • #13
I read that you don't have to get a cc kit when you use the c-springs because it won't lower it enough to throw it out of whack. Also, do you have to get new shocks and struts with the c-springs?
Lsredy2kstang
Look, I'm special, dammit
Woodstcock, Georgia
Nov 27, 2004
#14
  • Nov 27, 2004
  • #14
NO you dont have to get new shocks/struts but it would be advised. I have been running stock shocks/struts for 2 years now and it is not the best ride but doable. I am in the process of changing to the Mach 1 setup. You can find them at www.fordpartsnetwork.com or at www.gefracing.com Call GERacing for their prices may be cheaper talking to someone. A friend of mine got the rear shocks for only 29 bucks with taxes.
M
mysteed
Kennesaw, GA
Nov 27, 2004
#15
  • Nov 27, 2004
  • #15
If your looking for a nice drop for the lowest price, just do what I did. Buy Ford C springs and then find yourself a set of used GT shocks and struts (total cost of springs/struts/shocks= $170). Then get an alignment and poof!, your done.
SpectorV
1,872
Florence, Alabama
Nov 27, 2004
#16
  • Nov 27, 2004
  • #16
the rates are the same and that pretty much determines ride.... as far as springs influence goes. I have rode in cars equiped with everything from steeda to H&R to coil overs the steeda and the fms c are so close they are pretty much identical, even if there was a difference i would go C springs just for the price alone...
If you REALLY want to do it right go with h&r
MarcVIII
32
Cleveland / Akron, Ohio
Nov 28, 2004
#17
  • Nov 28, 2004
  • #17
Are you lowering for looks or handling advantage?
My reasons for lowering a car would be for the benefit of improved cornering (as well as a nicer stance). I'm looking to get a tubular K-kit up front with Bilstiens, coilovers, and CC plates. I want much improved handling with an adjustable ride so that I can drive comfortably and then race hard on the track or road course. I may have to wait to save for these parts, but when I get them I know I'll be happy with them.
Find a number that you want to spend on an aspect of your car (ex. handling, looks, engine, etc.). Then look for the parts in that range and see what people have to say about them.
You seem to want to spend a few dollars to lower your car. I've been told to first lower than rims rather than the other way around, so your on the right track. You have compartively shoped and are asking for whats better. The question I originally posed was:"Are you lowering for looks or handling advantage?" Answering this will help you better achieve your answer.
V
vrgn_mndrn
23
Glendale, Ca,
Nov 28, 2004
#18
  • Nov 28, 2004
  • #18
Since we are on the topic
I was looking into some strut / spring packages myself this weekend and found the TOKICO HP SHOCKS & SPRINGS for a decent price. Does anyone know anything about this package? I've heard nothing but good things about Tokico struts, but how about the springs? For the price, can I get a better combination of struts and springs? The reason why I want to drop the car is primarily for handling.
here is the link to the strut / springs and I want to purchase:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7937575215&rd=1
your help is appreciated
Ghostalker
184
Danbury, CT
Nov 28, 2004
#19
  • Nov 28, 2004
  • #19
that seems like a good deal ^^
this is what my brother did on his 01' GT Vert (taken from his website)
"I installed the Steeda G-Trac Stage 1 kit. It includes Steeda Sport Springs, lowering the car almost an inch and half. A Steeda Strut Tower brace was included, along with Steeda 3-bolt Camber/Caster Plates. Along with the kit, I bought and installed 2 Rear Tokico Blue Hi Performance shocks in the rear."
I had no idea what he hod on there, i thought it was tokico all the way around... one would imagine a "Steeda G-Trac kit" would cost alot more (he just left to go back to college after thanksgiving brake an hour ago)
J
juice05
#20
  • Nov 30, 2004
  • #20
Hey Thanks for all the feedback....You guys are so helpful. I Have a 98 Mustang convertible and the new 05, (which is half my dads and have mine) Im not adding mods to it soon ill wait to see what comes out in the market for awhile. I want to my convertible a litle bit for looks because Im adding the the cervinis front bumper the one from the stalker kit. As we speak my mustang has stock so i figure i can make it look aggresive by dropping it a bit im also adding the 18inch cobra rims too. I dont want to break the bank that much because to tell you guys the truth im also in need of, a new hood, rigth fender,back bumper, and 2 new air bags...My younger bro took my car out and got into an accient with a flat bed truck lucky for us we only paid $1500 for damages to the truck and for my mustang had no insurance at the time because I was in school and no one was suppose to drive it till I came back about 1yr later....but they did... so my priority is to fix my car and at the same time lower since im doing all these changes. So any advise or comments would be helpful. Sorry i know its quite long but you guys been so helpful I just wanted to let you guys know what my situation is.
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
H
New here and thanks
  • HoosierD420
  • Aug 30, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 30, 2026
HoosierD420
H
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
F
For Sale 03 Redfire Cobra Convertible
  • FastFox5oh
  • Jul 14, 2026
SN95 Mustangs For Sale (1994-04) Jul 14, 2026
FastFox5oh
F
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
