Ok guys,
I had my power steering rack go out on me last week. I replaced it with the ford exact same unit. The thing I did different is order the poly off rack bushings for it thinking they would help out. Now when I leave my drive way it sounds and feels like it is binding and popping at full tilt when turning. Sorta makes the car jerk a little.
Could these poly off rack bushings be the culprit?
My front suspension is setup with a tubular K and coilover setup. Also caster camber plates.
Im going to remove the offset rack bushings and put the factory rubber ones in and try it.
Any advice or comments?
Thanks
Thanks
