steering "chatter"
Original Owner
Michigan
When the car is parked and running and the steering wheel is turned, you can feel a chatter in the steering wheel and you can see the front wheels chatter also. Any ideas on whether this is the P/S pump or the rack? I couldn't find any leaks and the fluid level is good. If I have to change the rack do I buy the "performance suspension" unit for an exact replacement? Thanks for any input.
d0es the car have l0ng tubes? just a questi0n. but im leaning t0wards the rack als0. the valve is pr0bably getting stuck at full l0ck and n0t releasing pressure. and yes, get the 0ne f0r the perf0rmance suspensi0n
concerning the long-tubes question....I hope I don't sound like too much of an idiot here......I'm assuming that you're asking about the exhaust headers. I've got Bassani's ceramic-coated equal-length headers. They were a nice-fitting replacement for the stock headers. Rest of exhaust is stock. I'm going to put in an order for a rack and pinion assembly right now. Thanks for the help.:flag:
If you rev the motor up a little, does it help? The Ford pumps dont normally like to see wheels turning with brakes-on and while stopped (the pump has it's least power, yet the coefficient of friction is greatest).
One other thing to check is that the belt is trying to studder over the PS pulley.
Good luck.
is it a c0nstant p0pping 0r it just p0ps 0nce 0r twice? he reas0n i ask is because a l0t 0f pe0ple have a pr0blem with the steering shaft hitting 0ne 0f the primaries 0n the header. with equal length y0u might have that pr0blem but i w0uld h0pe n0t with bassani. just s0mething t0 check. l00k at the header right by the steering shaft and see if it l00ks like its being rubbed 0r hit. p0ssibly the m0t0r m0unts are bad and the m0t0r is sitting d0wn l0wer than n0rmal and hitting. it c0uld als0 be tie r0ds. id check f0r play in the fr0nt suspensi0n bef0re thr0wing parts at it. g00d luck
:bang:
The rack is replaced. I bled the hell out of it: over 3 quarts through the pump and out the return line. After reconnecting the return line I cycled the steering lock to lock over 50 times. There were no bubbles and the fluid looks great. No leaks at any of the lines. The headers have good clearance with the steering input shaft. The serpentine belt is not slipping on the P/S pulley. Chatter/studdering remains at any RPM through 4K when the car is parked and the steering wheel is turned. The only thing left is the P/S pump, but I'm mulling over your comment about the Ford pump being weak, so I don't want to throw any more $ at it. I'm already $130 into this. If anyone is willing, I'm curious to see if anyone else has this condition. If so, does is affect driving? Should I even be concerned about this? Thank you all so much for your input. I hope that I can be of help to you some day.
Just to let you know, I replaced my rack, pump, and all lines. Everything was brand new even fluid. My car was not doing it when I replaced all I was just looking for better steering feel and the original parts were wore out anyway. I put a sn95 rack for tight steering feel and now I have this problem also. I would guess it to be air in the system or a front end alignment issue. If you say you bled the system that much, my only guess would be alignment. This is only a guess though. Let me know what you find out so I can get it fixed also because your problem sounds identical to mine.
:shrug:
I have replaced the power steering pump with a rebuilt Ford unit from Autozone. I have a fresh alignment. I installed an in-line filter in the return line for the pump. After all of this, absolutely nothing has changed. I am stumped. I'm done throwing money at this problem, so I guess I will have to live with it. The chatter does not occur as long as the car is rolling. Park it and then turn the wheel and about half way through the sweep the front wheels do their #@!$ shake/chatter thing (can feel it in the steering wheel). If anyone ever finds a solution to this problem, it will be worth gold. Even the alignment shop (a "front-end specialist") was stumped. Thanks for all of the moral support along the way.
The 94-95 rack and PS pumps dont seem to have this issue - that might be a solution in the future. I think a guy or two on here has retrofitted the 94-95 components.
Good luck.
