Steering problem...need help....
  • Thread starter Thread starter dkeiser1989
  • Start date Start date Mar 17, 2007
D
dkeiser1989
15
  • Mar 17, 2007
Ok here's the situation: my '89 lx sat for about 3 years. before pulling the motor, I had replaced the shocks, struts, and steering rack. It also had new coil springs which were about 2 years old at that point. After finally getting it running again last summer, I found that the steering was waaaay off. Basically, it feels like the car is trying to change directions, sort of wandering. So I had it aligned, and the problem got better, but not completely fixed. I saw the computer screen when the car was on the alignment machine, so I'm satisfied it was aligned properly. I replaced the steering rack bushings with the two piece aluminum ones from maximum motorsports, installed new end links and sway bar bushings, a flaming river steering shaft, and finally, a new steering rack and tie rods. The problem has not gone away. I don't know what else to check. I can't find anything broken or loose. Does anybody have any ideas what to look for next? Thanks.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Mar 17, 2007
  • Mar 17, 2007
if the alignment was done properly you might want to look at the tires...might have some issues from sitting so long or another trip to a more qualified alignment shop if the previous job is in question. Also a narrow tire on the front will sometimes leave a car that likes to wander a bit with the contour of the road...but should have no 'pull' feeling on a smooth level road.
HISSIN50
34
129
Mar 17, 2007
  • Mar 17, 2007
Nice thoughts from Derek above.
Also, what was your caster set to?
Good luck.
whtpny
338
Spokane WA.
Mar 17, 2007
  • Mar 17, 2007
If it is lowered did you use the offset rack bushings. Made a huge difference in my car. What about a bumpsteer kit?
Juiced87Notch
500
Gresham, Oregon
Mar 17, 2007
  • Mar 17, 2007
check your front bearings, if there loose enough that can cause a wobble and or wandering situation along with horrible tire wear, and destroy the spindle if it gets bad enough.
D
dkeiser1989
15
  • Mar 18, 2007
Thanks for the replies...the car has new tires on it, stock size, so that's not the problem. I'm not sure what the caster is set to, but I'll find out and check it against the specs. It's got the offset rack bushings. Great idea about the bearings, I never thought of that. Is a bump steer kit necessary? I've got the FMS springs that drop the car 7/8" in the front and 3/4" in the back, I believe. Before the car sat, I had it aligned a couple of times with no bump steer kit, and I never had any steering issues. I've also got caster/camber plates for it. So I'll throw those on and get the alignment checked again. Thanks. :SNSign:
F
FastFord58
28
  • Mar 18, 2007
Did you remove the swaybar from the car? What do your endlinks look like?
D
dkeiser1989
15
  • Mar 18, 2007
it's still got the sway bar, with new bushings. end links are also brand new.
K
krallman
96
Hurricane, WV
Mar 18, 2007
  • Mar 18, 2007
I dont know what kind of tires you are using but sometimes the cheap ones the metal bands in them will break causing the car to wonder. Check the stagger (diameter) on your tires. Make sure there within and 1/4 of each other or that could cause problems.
carnutz
12
#10
  • Mar 18, 2007
  • #10
Hello
When I have had that sort of problem it was end links, Tires, or ball joints. You can jack up the front end one side at a time and grab hold of the tire and wiggle it see if you hear any clunking or movement without the rack and steering moving.
Hope this helps.
whtpny
338
Spokane WA.
Mar 18, 2007
#11
  • Mar 18, 2007
  • #11
Yea I have the B springs myself and am going to get the bumpsteer kit because of the difference the offset rack bushings made. If you look at the tie rod ends from the front you can se the angle that they are at and see how the longer tie rods will help.
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
J
Severe shaking/vibrations in steering wheel
  • jacket999
  • May 20, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 1, 2025
NtheGAME
N
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
