steering problem
mob
the guy who hits on his mom
Oct 3, 2003
2,566
136
104
Dallas, TX
Hey guys, I tried searching this but ive never heard of this. Latley when I go to turn my wheel, once I get to about a 1/2 turn, it just stops, not like its hitting something, and not like the car is pulling to a side, but like the wheel dosent want to turn any father, or it wants to straighten out. Kinda like if you have no power steering. But its like once I get to 1/2 turn the power steering shuts off. itll do it all all speeds, not as bad when im going faster but you can still feel it, and at slower speeds like doing a 90 degree turn at like 20mph the wheel will feel like it locked up, and ill either have to put all my force into it to turn more, or itll SNAP back straight. Hasent really cause a problem, no danger, but its annoying and cant be normal. I checked my power steering fluid and it was low, I put some more in but didnt fix the problem. The rack and pinion was replaced like 2 years ago.
Oh and it does it on the skinnies, and the cobra r's so its not the wheels. Could it be an alignment issue? All front suspension is stock, with sway bar deleted.
Don't rule out the rack because its only a couple years old, mine is only 4 years old and leaks like a sieve, your problem sounds like a valve issue in the rack, like when you get to a certain point the rack bypasses all the fluid so you lose power steering.
Yea its a discount auto replacment so I wouldnt doubt it being a problem, anyway to check if this is the problem? How hard are these to change? Should I start looking for a new rack?
i dont know how to check for it, but its not going to be like a 20 min change, it will take a while. i think that you need a special tool (or maybe not) to take the fittings off, you could probably get away with regular openended wrenches.. also you'll have to get her re-aligned..
if you're driving and this happens on say a sharp corner at 40mph, the car wont turn and you go straight off the road, or sraight into another car/person..it's your car, but i'd get that fixed as soon as possible, also check tie rod ends, etc for wear, good luck
~Mark~
I understand what your saying, but right now i have about 5 bucks in my bank account. I get about 300 bucks every two weeks. And I have about $230 in tickets to pay. My engine is still acting up. I cant buy a new rack for 90 bucks, and pay someone 200 bucks to install it.
It hasent been long since Ive been under tehre, maybe a week, and from what I can remember, the tie rod ends look fine, but that little squishy part is ripped, im not sure what it does, or if that could cause a problem.
the squisy part is the rubber boot, that could let dirt in and cause one of them to bind up..you can remove the nut, pull the tie rod tot he side and check the movement by hand, if it feels like it's got sand or rust in there you'll need to replace it..i know what you mean by low on funds, you can get cheap used parts are a wrecking yard, or sell stuff on ebay..getting tickets suck, especially when you cause a small wreck, have to fix the mustang already and on top of that you get a 153.00 ticket..sometimes you just cant win
~Mark~
Changing the rack is no big deal, if you can do a head swap yourself you can change a rack yourself, if you count how many threads out the tie rods are on the rack thats in there, and duplicate it on the new rack, your alignment should be good enough to by you some time before having to get an alignment.
I have replaced the steering rack twice... The rebuilt rack didn't last as long as the original rack. Pm or call me if you need help.
The two inner tie rod ends are usually what wears out, and at $45 each, it's better to get a replacement rack assembly since they are part of the package. The rack is about $100 + a $40 refundable core charge, which you get back when you return the old rack. Be sure to ask for the GT or high performance rack, it has fewer turns lock to lock than the standard rack.
The flex coupling for the steering shaft needs to be disconnected before you can get the rack out. You should disassemble the coupling by undoing the 2 bolts that hold it together. The lower part of the coupling will then come out with the rack, and can easily be removed.
The tie rod ends can be removed with a tool that looks like a giant "pickle fork", it's less than $8, or some stores will rent/loan one. Remove the cotter pin & nut on the tie end, stick the tool between the rod end and the arm it connects and hammer away. The bigger the hammer, the easier it comes apart.
Remove the two bolts that bolt the rack assembly to the frame and then pull the rack down. Get a catch pan to dump the fluid in when you disconnect the hydraulic lines. I replaced the rack mount bushings with some Energy Suspension urethane ones. When you re-install the rack assembly, put the rear bushings in the rack assembly and lift it into place. Then install the front bushings & washers and tighten down the nuts. Doing it this way makes room for the hydraulic lines without having them bind against the frame.
To change the tie rod ends, do them one at a time. Loosen the jam nut 1/4 turn, then unscrew the tie rod end from the rack. Turn the jam nut back 1/4 turn to return it to its original position. With the tie rod end removed, use a machinist square to measure the distance between the end of the threaded rod and the jam nut. Sit the bottom of the square against the end of the threaded rod, and the end of the blade of the square against the jam nut. Duplicate the measurement on the new rack and then install the tie rod end and tighten the jam nut. Then do the other side: the front end will need aligning, but the toe in will be close enough to the setting of the original rack to drive.
Buy several extra quarts of fluid to run through the system to flush it when you change the rack. The car needs to be up on jackstands for the next step. Fill the pump up, start the car, and turn the wheels lock to lock to bleed the air out. Then stop the engine, disconnect the low pressure hose (the one that is secured with a hose clamp) and drain the pump. Re-connect, refill and do it several more times or until the fluid looks clear and not burnt or black.
