If the wheel itself is wobbly, then you need to take off the plastic covers to the steering column, remove the turn signal switch, and you will see to bolts underneath it ( one on the top of the column one on the bottom). tighten them up, or better still, use some loctite and then tighten. Put everything back together and you should be good to go.
