Hi. I have two questions... the first has to do with the steering shaft rubbing my equal length header on the driver side... is there a smaller shaft or something I can do other than denting my header where the steering shaft rubs... I have to take my headers off and fix where the one is bent anyways... cause I can't fix my exhaust leak... and it is because the headers aren't matting up right.... so while I'm at it I should probably deal with the steering shaft problem... other question is related to gears... I have read allot and am set on 4.10's one day... is it necessary to get the master install kit? Someone said I would need a press.. or something... is it a easy install... how long would this take me.... ??
