Steering Wheel Alignment
  • Thread starter Thread starter jakekeys
  • Start date Start date Mar 24, 2021
J
jakekeys
17
San Diego
Mar 24, 2021
  • Mar 24, 2021
Hi, after installing a replacement steering wheel on my 92, I noticed the alignment is now off...the new wheel points to about 2oclock. Is this an easy fix or should I bring it in?
Thank you
J
jakekeys
17
San Diego
Mar 24, 2021
  • Mar 24, 2021
Thank you
I also noticed that there is a factory note on the column that says something about re-centering the wheel, but I could not figure out how that is done.
General karthief
Mod Dude
Aug 25, 2016
28,051
10,675
213
polk county florida
Mar 25, 2021
  • Mar 25, 2021
Stock wheel?
Mustang5L5
Mod Dude
Feb 18, 2001
43,330
18,058
224
Massachusetts
Mar 25, 2021
  • Mar 25, 2021
They only clock one way. So if you take a stock wheel off, and put a stock wheel back on, they should align the same way assuming it's a stock steering shaft that is not clockable. More details would help us determine if any sort of mismatch in parts exists.
There is no way to center the wheel on the column. You would center the rack by this procedure. Go to the end and ignore the beginning of the instructions
https://www.maximummotorsports.com/assets/install/pdf/steering/MMST-11r2.pdf
After this process you would need an alignment, but if you get this far something is off. Take a stock wheel off and put a stock wheel on should be the same. What wheel did you buy?
Reactions: jakekeys
J
jakekeys
17
San Diego
Mar 25, 2021
  • Mar 25, 2021
It's the 5.0 Resto direct replacement (https://lmr.com/item/LRS-3600R/mustang-steering-wheel-leather-1990-93). At some point in the process I accidentally made the steering wheel lock by turning the wheel too much, not sure if that would have created a misalignment.
General karthief
Mod Dude
Aug 25, 2016
28,051
10,675
213
polk county florida
Mar 25, 2021
  • Mar 25, 2021
Nope, that would not do it.
Reactions: jakekeys
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
For Sale 2006 Mustang GT Steering Wheel with Cruise Controls
  • lenko
  • Sep 3, 2026
  • Other Classifieds
Other Classifieds Sep 3, 2026
lenko
Fox Alignment Suggestions
  • PonyGTrider
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2025
PonyGTrider
Strut Tower Help!
  • 93Nifty
  • Jan 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
General karthief
Sloppy steering wheel
  • cnorman31
  • Nov 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 2, 2025
Monkeybutt2000
M
