steering wheel shake
40th_GT
14
i have an 04 gt spd with 2500 miles on it and at around 50mph without breaking or anything i get a steering wheel shake it not agresive but it pretty noticable any one have any suggestions. :shrug:
Do you have a vert? I have the same shake. Took it to the dealer four times and all they did was balance the tires and say its normal. I also installed the aluminum drive shaft and subframes which all helped but not totally eliminated it. Definitely have it checked to make sure nothing is wrong, but I think some of the shake is just inherent to the convertible.
if balance and alignment work out, then look at the tires. When i bought my GT i put 4 brand new tires on it. 2 of them w/less than 500 miles had broken (defective) belts. This caused the same sort of feeling. Its tough to see visually unless you know what you are looking at. Run your hand around the middle of the contact surface on your tires. If you feel and bumps or dips, thats it. Good Luck!
