  • Mustang Sound & Shine All
Stereo Cutting out
  • Thread starter Thread starter 92Patrol5.0
  • Start date Start date Sep 13, 2005
9
92Patrol5.0
1,076
Cedar Rapids, Iowa
Sep 13, 2005
  • Sep 13, 2005
I have 2 8" subs with a 300 watt amp in the trunk. I have had this setup in the car for several years with no problems. Over the last couple days I had the battery disconnected while doing some work. I hooked everything back up, and now when I turn the volume up to a certain point, the speakers start to distort and then the unit shuts off. It turns back on, but if left at the same volume it shuts down again..... etc. I have never had this happen before. I'm confused as to what is going on? I have a kenwood cd deck. I don't know if one of the settings is messed up or what. Anyone have any ideas?
J
jduncan_69
9
  • Sep 13, 2005
Try taking the fuse out of the power wire for the subs for starters and see if it still does is, you are going to have to check each component at a time to find out what area the problem is in first.
9
92Patrol5.0
1,076
Cedar Rapids, Iowa
Sep 13, 2005
  • Sep 13, 2005
Ok, I will check that. It just doesnt make any sense to me. Nothing is different from when I disconnected the battery. All I did was disconnect it for a few days, then reconnected it today and now this. UGH!
9
92Patrol5.0
1,076
Cedar Rapids, Iowa
Sep 13, 2005
  • Sep 13, 2005
I pulled the fuse to the amp, disconnected the wires from the radio and it still did it. I also tried leaving the amp and speakers hooked up, and fading it all to the rear or all to the front. When I did that, I could put the volume up higher before it cut out. Otherwise, when I have the fader balanced from front to rear it cuts out. I used to be able to crank it up to 23-24 on my volume with no signs of cutting out. Now if I turn it up to 20 it cuts out. I just don't get it. Nothing changed and all of a sudden this happens. I'm frustrated. I went through the wiring and didn't find anything out of the ordinary.
9
92Patrol5.0
1,076
Cedar Rapids, Iowa
Sep 14, 2005
  • Sep 14, 2005
Any idea what would make the stereo shut down when the volume is turned up to a certain level? I spent about an hour and a half looking through wires and playing with the radio setup and I had no luck. With the amp and subs disconnected completely the radio cut out. A friend of mine has this same problem with his stereo on his boat. Once he turns it up to a certain volume level it cuts out. Anyone know what causes this? I would guess it either has to be a fault in the radio, or there is something wrong with the wiring. But like I said, nothing changed from the time I disconnected the battery cable to the time I reconnected it. I got in the car and turned on the radio and noticed the problem. I'm baffled.
iskwezm
4,159
20
79
Rowland Heights,California
Sep 14, 2005
  • Sep 14, 2005
check your power wires and grounds.
9
92Patrol5.0
1,076
Cedar Rapids, Iowa
Sep 14, 2005
  • Sep 14, 2005
I will check on that. It didn't seem like anything was loose or disconnected but I may have overlooked something. I will check again though.
9
92Patrol5.0
1,076
Cedar Rapids, Iowa
Sep 15, 2005
  • Sep 15, 2005
I think I figured out my problem. I think my battery is on its way out. I have another thread going in the 5.0 tech section about the battery going dead. My battery loses charge after sitting for a while and doesn't have enough juice to turn the car over, but has enough to run the lights, stereo, etc. SO, what I think is happening in my case..... is I am sitting in the car messing with the stereo with a low charge on the battery. When I turn the stereo up, it's drawing too much power and is shutting off. The reason I think this is the problem, is because if I sit with the stereo on at even a low volume, if I turn the headlights on, the stereo shuts off and comes back on. The same thing it does when I turn the volume up too loud. Does this sound like it could be the problem? I am taking the battery in to be tested on Saturday. It sounds logical to me.
iskwezm
4,159
20
79
Sep 15, 2005
  • Sep 15, 2005
How big is your charger???,thats sounds very possible,but put your charger on a higher amperage and then try it again,see if the charger can supply the needed power.
9
91_4ourBanger
255
#10
  • Sep 15, 2005
  • #10
what cuts off? the subs? the amp? the cd player? the whole system?
98stangv8
1,036
fayetteville, nc
Sep 15, 2005
#11
  • Sep 15, 2005
  • #11
check the alternator...
92Patrol5.0
1,076
Cedar Rapids, Iowa
Sep 16, 2005
#12
  • Sep 16, 2005
  • #12
The reason I'm thinking battery is because after I jump the car and let it run for a while. I can shut it off and restart it with no problems. However, if I leave it sit for a while the battery will drain and not have enough juice to turn the engine over. If the alt. wasn't charging, I wouldn't be able to shut the car off and restart it after 30 mins would I? I'm taking the battery in Sat. morning to have it load tested. If the battery comes out being ok, I will have the alt. tested. I swapped a 130amp alt. in about 2 years ago. Luckily I got one from the parts store with a lifetime warranty, so if that's the problem I can get a free replacement. I will let you know how the battery test turns out.
As for what shuts down when I turn the volume up too loud, or turn the headlights on........ The stereo itself turns off as well as the amps turning off. It says off for a couple seconds and then turns back on again. However, if you don't turn the volume down during that time, the stereo will come back on for just a few seconds and then turn off again. I'm guessing b/c too much power is being drawn and the battery doesn't have enough juice to supply so the stereo turns off. This is just my guess at this point. I won't know until I have the battery tested and get a full charge to check the stereo with to see if it still does it with full power.
iskwezm
4,159
20
79
Sep 16, 2005
#13
  • Sep 16, 2005
  • #13
you have some dead cells in the battery and it cant sustain a load,mine is doing the same right now.Let it sit for more then 3 days and forget it.
9
92Patrol5.0
1,076
Cedar Rapids, Iowa
Sep 16, 2005
#14
  • Sep 16, 2005
  • #14
That's kinda what I figured. I wasn't really thinking about what could be wrong when it first happened. I switched the fuse port my water temp and oil pressure gauges were hooked into and thought I had fixed my problem that was draining the battery. Then the next day it was dead again... So I got mad and decided to listen to some tunes and it started cutting out on me like that. So I looked through everything, not thinking it could be the battery not having enough power to keep up. So I'm hoping that's all it is, and I'll find out tomorrow and see what happens.
9
92Patrol5.0
1,076
Cedar Rapids, Iowa
Sep 18, 2005
#15
  • Sep 18, 2005
  • #15
Well, battery tested as dead. Put the new battery in a wallah! So that was exactly what my problem was. Thanks for all the help everyone!
G
Electrical Getting good ground in 1991 Fox Vert for amps - getting popping noise when I turn on the lights?
  • gvanginkel403
  • Apr 11, 2026
Fox 5.0 Mustang Tech Jul 21, 2026
gvanginkel403
G
Stereo snakes nest; what am I missing?
  • Scott_S
  • Aug 29, 2025
Mustang Sound & Shine All Sep 24, 2025
Scott_S
Radio, Speaker Upgrades
  • TripleYellow
  • Apr 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 24, 2026
TripleYellow
  • Mindseye007
  • Aug 16, 2026
Mindseye007
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
