  • 1994 - 1995 Specific Tech
Sticky Clutch
  • Thread starter Thread starter modifiedstang
  • Start date Start date Jun 2, 2005
modifiedstang
18
TX
Jun 2, 2005
  • Jun 2, 2005
My clutch is abnormally hard to push down for some reason. I don't know if i need a new clutch kit or what. Any ideas?
I
iwashmycar
20+ Year Stangneter
Apr 7, 2004
1,236
Columbus, Ohio
Jun 2, 2005
  • Jun 2, 2005
mine was and the cable was binding. New cable and quadrant should fix it right up!
It was so hard to push that I found out that it was breaking through the firewall.
modifiedstang
18
TX
Jun 2, 2005
  • Jun 2, 2005
do u know where i can find a tutorial for that?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jun 2, 2005
  • Jun 2, 2005
It is either bad cable routing or the cable itself is gummed up inside the rubber/plastic housing.
Also the bearing retainer the throwoutbearing rides on can get gauled up and cause a non-smooth "ride".
Good Luck!
modifiedstang
18
TX
Jun 7, 2005
  • Jun 7, 2005
Good Luck!
OK, i was also told there was a setting that u can tighten or loosen to change the smootheness of your clutch. Is that true?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jun 7, 2005
  • Jun 7, 2005
I am not aware of any setting like that. They make adjustment mechanisms (like a firewall adjuster or adjustable cable) that you can tighten or loosen to make the clutch grab in different locations. But nothing to make it smoother alone
modifiedstang
18
TX
Jun 7, 2005
  • Jun 7, 2005
OK, cool.
Do you know where i can learn further about a new cable quadrant or learn how to check for a bad cable routing?
HISSIN50
34
129
Jun 7, 2005
  • Jun 7, 2005
David might have some info for ya - if not I would read Jeremy's article.
Good luck.
modifiedstang
18
TX
Jun 7, 2005
  • Jun 7, 2005
What are david and jermey's screen names?
HISSIN50
34
129
Jun 7, 2005
#10
  • Jun 7, 2005
  • #10
David is 5 Spd GT (posted above on your thread). He is very knowledgable with this stuff and has some nice write ups.
Jeremy is V8 Only. In his sig he has a link to his website which has a good article on clutch dynamics.
Good luck.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jun 7, 2005
#11
  • Jun 7, 2005
  • #11
modifiedstang said:
OK, cool.
Yeah as JT pointed out...v8only (Jeremy) has a picture he will post for you where it shows the proper cable routing and he has tried a couple quadrants out. I believe he likes the UPR 3 hook quadrant (more adjustability). I am happy with my Steeda 2 hook quadrant...
Try PMing him...do a search for his name below
v8only
Good Luck!
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
T
Drivetrain Take a look at this clutch pedal
  • TNmach1
  • Sep 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 18, 2026
TNmach1
T
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
Clutch pedal to Quadrant lag
  • Potomus Pete
  • Aug 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
