Still fighting the Power Steering
  • Thread starter Thread starter wahoo23
  • Start date Start date Dec 30, 2007
wahoo23
63
Parker, Colorado
Dec 30, 2007
  • Dec 30, 2007
I recently replaced my power steering pump, hoses, slave cylinder and had the control valve rebuilt. I put everything back to gether and the P/S finally works great, but... I now have a leak where one of the short hoses enters the slave cylinder. Everything is new, and all hoses are tight (and not too tight, I don't think). Anyone have any ideas? Bad hose?
TD68302
57
Arvada, CO.
Dec 30, 2007
  • Dec 30, 2007
Make sure that the hard line is centered in the tube nut, if it is not centered it can leak.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Dec 30, 2007
  • Dec 30, 2007
This is true. If it is still leaking after you retighten the line then the flare fitting may be damaged. You can get around this buy buying a piece of copper from a brake supply store that is made to go into the flare fitting. Put them in and tighten them down and it should stop the leak. Also, use a little RTV on the threads to help prevent leakage.
wahoo23
63
Parker, Colorado
Feb 13, 2008
  • Feb 13, 2008
After re-seating the hard line, and adding a little RTV, the leak seems to have stopped. I think (as of right now) I've got the PS problems licked!
Thanks, all, for responding to both of my PS threads.
yeloxr7
429
  • Feb 19, 2008
Putting RTV or any other compound on the threads of a flare fitting will not help with a leak. I would think that RTV would lubricate the threads, making it easier for the fitting to work its way out of the part it is threaded into. Besides, it is possible for bits of the RTV to get into the system, and that could cause problems.
The sealing on a flare fitting takes place between the flare and the seat. Sometimes the flare will crack or the seat will wear in a spot, thus causing a leak. The seats are removeable and replacements are available. Some folks recommend replacing the seat when a hose assembly is replaced.
wahoo23
63
Parker, Colorado
Feb 19, 2008
  • Feb 19, 2008
Interesting...All parts were new and still leaked. After applying the RTV, the leak stopped. Maybe it was a case of a better seat when I re-installed the hose... Either way, I've got it licked! Thanks!
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
Power steering hoses
  • Teen'93stang5.0
  • Apr 3, 2026
1974 - 1978 Mustang II Talk & Tech Apr 14, 2026
Teen'93stang5.0
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sunday at 4:40 PM
manicmechanic007
