Still leaking
  • Thread starter Thread starter 1993SVT
  • Start date Start date Jun 8, 2010
1993SVT
29
  • Jun 8, 2010
I just replaced a rear main seal but also installed the crankshaft repair kit before doing so. The car did not have any leaks at all and I drove it for a few hours within a 2 day period, checking periodically for possible leaks. I parked it in the garage and put newpaper on the floor to make sure. 2 days went by and I took it out of the garage and there it was on the paper, oil. It wasn't a significant amount but it still concerned me, along with putting me in a really bad mood. I also bought a new set of valve cover gaskets because they were in need of replacement but I have only replaced the passenger side so far. They really didn't leak much but you can't see what's going on with the driver side seal unless you take the intake off(which I haven't just yet). Could it possibly be the valve cover gasket being that bad that it's leaking oil down the back of the engine, making it seem like it's the rear seal? If anyone has any input on this, I'd really appreciate it. thanks all.
strtrcr50
Previously from Dirty Jerzey exit 7a
Jun 8, 2010
  • Jun 8, 2010
Odds are, it is still the rear main seal. Possibly, when the person before you changed the rear main, he/she nicked the crank. However, the first thing I would do is replace the PCV screen and PCV valve after making sure I had good vaccuum to the PCV valve. If the PCV system is not working, you will build up crankcase pressure and the motor will leak.
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
Engine Oil leaking
  • greenflash79
  • Apr 1, 2026
  • 2007 - 2014 Shelby GT500 Tech
2007 - 2014 Shelby GT500 Tech Apr 6, 2026
greenflash79
M
Drivetrain T5 Transmission Leak at Tailshaft
  • MDrisc
  • Jun 17, 2025
Fox 5.0 Mustang Tech Jun 18, 2025
AeroCoupe
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
